Old 09-01-2011, 03:21 PM   #1
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Framing for Air Conditioner
At the opening for the air conditioner on the roof are the 2.2's that frame the opening suppose to be curved to match the curved roof or should they be flat to match the bottom of the air conditioner?
silver 67
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 09-01-2011, 05:00 PM   #2
1972 25' Tradewind
Madison , Wisconsin
Having just put a new AC in I know what you are talking about.
The 2x2's are to provide a base when screwing down the inside frame against the gasket---something to provide resistance and prevent the roof & wall/ceiling from getting crushed together. If you have the curved ones it seems logical to use them as there would be less stress on the skin. Mine were not curved but were shortened and served fine.
I have heard metal spacers (Aluminum) are best, in the event of a condensate leak--makes sense, but a decent installation should negate that problem.
Smokin Camel is offline   Reply With Quote
Old 09-01-2011, 05:28 PM   #3
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Hello,
On my 67, it was not ordered with an ac.
I had cut into the skins, fabricate C channels from aluminum L angle to create support for my heat pump. I used Olympic rivets for strength.
I have a few pics below.
So far so good, no leaks.
ID:	139203   Click image for larger version
ID:	139205   Click image for larger version
ID:	139207   Click image for larger version
ID:	139209   Click image for larger version
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Remove Air Conditioner to fit in storage? Geobie07 Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-01-2016 05:58 AM
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
What's a fair price range bosshog Classic Motorhomes 4 08-11-2011 09:22 PM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
