Old 09-11-2019, 04:04 PM   #1
SailAS's Avatar
2007 25' Safari FB SE
Sugar Land , Texas
Fishing wire for 2nd AC in 25' FB
Well I finally bit the bullet and got a second AC to install in my 2007 25 FB Safari SE. Since it only had 30A service coming from the factory they really did not plan on 120V wiring to the Front Roof Vent ( although there is a thimbled hole in an adjacent rib presumably for 12v wiring for a Fantastic Fan but there is no wire there of any kind).
I've already installed a second AC Breaker Panel and changed out the power entry for a 50 Amp unit ( see attached photos) & wired the 2nd panel with 10/3 like the factory panel (AKA each panel has it's own dedicated 10 AWG conductors to the 50 Amp inlet) but I am "challenged by the branch wiring.
Although I have fished a messenger from the new AC Circuit Breaker panel to the area behind the Shower and even up to the top of the Shower enclosure ( That's where the power roof vent is - see picture) but how do I get from there to the other side of the adjacent horizontal rib so I can use the "factory" available thimbled hole to bring 120V to the Air Conditioner.
So far I have been unable to find any "thru-hole" in that rib ( there is a good Video from the Mother Ship about where are the wiring runs are).
Anybody got any thoughts?????
Thanks , D
Name:	2nd AC Panel.jpg
ID:	351952   Click image for larger version
Name:	Access via Fan.jpg
Name:	Frame intersection.jpg
ID:	351955   Click image for larger version
Name:	50A Inlet.jpg
Dwight & Ellen + (the Beagles)
2011 F350 SRW King Ranch, 6.7L, 3.55 ELD, Ranchos, Hellwig w/ Reese Dual Cam & 1200# bars. 2007 Safari 25 FB SE (stock - well sort of)
SailAS is offline   Reply With Quote
Fishing wire using existing wiring. NeuroNerd411 Computers, Internet & Satellite 5 05-09-2019 11:13 AM
2nd a/c failed for 2nd time Bgibbs Furnaces, Heaters, Fireplaces & Air Conditioning 15 01-02-2019 05:23 PM
fishing in Alaska or non fishing baylito99 On The Road... 11 06-24-2012 07:25 PM
12 volt wire fishing moosetags Electrical - Systems, Generators, Batteries & Solar 10 02-21-2007 06:41 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
