Old 01-19-2009, 07:10 PM   #1
mouth012006's Avatar
1974 Argosy 24
Science Hill , Kentucky
Images: 51
Finishing the removal of the furnace
The PO did not finish the removal of the complete furnace....We did some demo today taking out the kitchen cabinets for a total replacement with new ones. We found that they apparently started taking out the furnace then changed their minds...we want to finish taking this out but not sure about the pipe that runs from it and the vent that goes into the floor....
Kevin & Monique
New to A/S---Not to Honey Do's
Sweetie (lab) Snickers (lab) Blackie(lab)
Dotz(daschund) CB (daschund) Oh and 3 kids!!!
TAC# KY-3
mouth012006 is offline   Reply With Quote
Old 01-19-2009, 07:36 PM   #2
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
If the pipe you mean the gas line, it goes through the floor and connects to the main gas line under the trailer. If you get under the trailer you'll see the gas lines. You'd need to disconnect it, shut off the valve if there is one, and cap the line and double check for leaks, patch the hole in the belly and floor to keep cridders out. The vent in the floor probably opens up to vents in other places in the trailer (like the bathroom). If it is in the floor you'll probably have to settle for covering it up and forgetting about it, since removal would either mean removing the belly pan or floor.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-19-2009, 07:45 PM   #3
1974 Argosy 24
Images: 51
okay, will relay that to the hubby...I think that he is going to start working on this tomorrow afternoon.
Kevin & Monique
TAC# KY-3
Old 01-19-2009, 09:32 PM   #4
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
So you both are doing an extensive remodel.......sounds like fun.
94Tri is offline   Reply With Quote
Removal of furnace Stone Ridge Furnaces, Heaters, Fireplaces & Air Conditioning 13 11-24-2008 11:13 AM
Furnace removal help! Roger2005 Furnaces, Heaters, Fireplaces & Air Conditioning 8 03-26-2007 09:52 PM
Furnace Removal The Flintstones Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-14-2006 12:06 AM
Furnace removal?? KHarris Furnaces, Heaters, Fireplaces & Air Conditioning 7 09-07-2006 11:54 AM
removal of furnace in 61 overlander heavyduty Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2005 04:50 AM
