Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 05-13-2002, 11:45 PM
Sojourner
Sojourner's Avatar
Profile:
Question Experiences with Carrier Air V installation?
On and off for the past couple of days I've been trying to properly install a Carrier Air V rooftop A/C on my '73 Sovereign. I've unassembled and reassembled the ceiling unit so many times now I can do it blindfolded. The two main problems I've encountered have been the compression of the exterior and interior skins (especially an aggravated deflection of the exterior skin at the rear of the 14"x14" roof opening) and not being able to attach the grille assembly to the ceiling unit due to a combination of the ceiling curvature and interior skin compression by the tightened down ceiling unit.
I've used cedar spacers between the skins and also between the ceiling and ceiling unit with some positive results, however I am still getting a bad deflection of the exterior skin to the rear of the roof opening.
Tomorrow I am getting a 16 or 14 gauge re-enforced stainless base plate fabricated to bridge the supports fore and aft of the roof opening for the rooftop unit to sit on. After I install this stainless base plate I will continue to work out the most appropriate spacer arrangement for both between the skins and between the ceiling and ceiling unit.
Two other issues I intend to address: 1) I will try to seal the gap between the straight ceiling unit grille assembly and the curved ceiling with gray open cell foam closure material, and 2) I am concerned about the negative pressure created between the inner and outer skins by the unducted routing of the return air through the roof opening where there is exposure to the insulated space between the inner and outer skins - I plan on using 2" open cell foam backer rod between the skins around the roof opening to seal this gap. If unchecked, both of these conditions will contribute to the intake of unfiltered air across the evaporator.
After the A/C unit installation is completed, then I have to lower the support bracket for the bedroom privacy curtain since the new (substantially lowered by spacers) ceiling unit has now displaced this bracket.
Despite all these minor problems along with no provision for a drip pan to drain to an internal condensate drain I am very pleased with the Carrier unit.
Does anyone else have any experience with the installation of the Carrier Air V they would care to share?
Get rid of these ads... register today, it's FREE
Old 05-15-2003, 01:23 AM
fiream29
Profile:
Just installed a new 15K BTU Carrier on my '87 Excella and went through some of the same problems as you seem to be having. I have some of the roof deflection you describe but it didn't seem too bad so I left it as is. I had a length of the weatherstrip used on the vent covers left over and it worked perfectly to seal the gaps at front and rear of lower unit.
The opening in my roof was framed all around by aluminum I-beam but the inner skin (vinyl metal) had been sloppily cut past the edges of the beams so I used duct tape to seal it. I used shims made to square door frames in houses to shim out and level the lower unit. They are wedge shaped and about a quarter inch thick at the large end. They come in packages of 15 or 20 and cost a buck or so.
Sure is a world of difference between the 15 year old Coleman and this new Carrier. Outside unit is very quiet and inside is tolerable. It was 97 degrees outside today and my unit hit 80 deg. inside temp. Trailer is in direct sunlight all day with no shade and awnings furled.
Old 03-09-2005, 02:53 PM
TOM CRUMP
TOM CRUMP's Avatar
Profile:  1970 27' Overlander
Braxton, Mississippi
Carrier AirV A/C
QUESTION: Is there a way to connect the water condensation hose to the new Carrier Install? We did a A/C swap on our '80 sov. The old Armstrong gave up on us. It was a bear of a job, The only downside is the water running off the roof. I did not see any way to connect the existing drain tube. The 15k btu unit is very quiet.
TC
vB code is On
Pingbacks are On
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 12:58 PM
Removing Air Pump & Stuff swebster Mechanics Corner - Engines, Transmission & More... 6 03-10-2004 06:23 PM
Air Spring Options for Softly Sprung Tow Vehicle? overlander64 Towing, Tow Vehicles & Hitches 15 11-29-2003 08:49 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
