Old 06-07-2004, 07:26 PM   #1
Cracker's Avatar
Pittsfield , Maine
Angry Electrical Furnace Problem
My water heater works great on LP - but for some reason the electrical element doesn't seem to be working. There is a hole with a "re-set" switch located in it that you're suppose to be able to set with a pencil eraser. I cannot detect any "click" when I push on the visible red "tag" to indicate whether or not a reset has ocurred. The switch at the heater is in the "on" position. Any suggestions?
THIS QUESTION WAS SUPPOSE TO BE FOR A "WATER HEATER PROBLEM" SOMEHOW I GOOFED UP AND TITLED IT "ELECTRICAL FURNACE PROBLEM." SEE THE SUBSEQUENT THREAD WITH THE CORRECT TITLE.
Cracker
Cracker is offline   Reply With Quote
Old 06-08-2004, 07:01 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Cracker
Any suggestions?
Edit: Cracker modified his original question, but I will let the following response stand:
But, I will assume the "reset" button you reference is a thermal overload switch. Long ago, I ran into a situation where I could not get a motor restarted. Since it had a reset button similar to what you described, I figured the motor had overheated.
Letting the motor cool for a couple of hours, I pushed the button. Nothing happened. [snip boring detail]...I found I was not pushing the button hard enough. Once I finally did, it reset with a distinct "click".
My suggestion is "Push harder".
Tom
furnace problem nwclassic Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-11-2007 11:15 PM
CO problem with furnace :eek: yukionna Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-25-2004 06:35 PM
furnace problem..... norbert Furnaces, Heaters, Fireplaces & Air Conditioning 12 11-17-2003 08:50 AM
Furnace problem Paul Daugherty Airstream Motorhome Forums 20 02-19-2003 03:31 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
