Old 11-02-2010, 09:18 PM   #1
Leicester , North Carolina
Electric furnace burning wire. Blows cold.
A few years back our mobile home electric furnace started blowing cold air. We checked it and seen that it had burnt a wire inside. We replaced that wire with higher grade wire, and it burnt that wire also. Element is fine, blower is fine, fuses replaced, but it keeps burning the wire and causes the air to blow cold. Someone told us to check the voltage regulator, because he had the same problem and said that fixed it. We are confused as to what a voltage regulator is, and when trying to look up that part we see nothing named that. Our furnace is an Intertherm brand. Our mobile home is a 1986 model, so the furnace is pretty old. Model # is FEH-012HA. It is 41k btu, 2.5 single speed. Not sure if that is all you guys need to know, but hope you can shine some light on this please. We have been without our furnace for many years now, relying on small space heaters. We just can't afford to pay an electrician to come out and check it. We just need to know what part we need to replace.
janix2010 is offline   Reply With Quote
Old 11-03-2010, 05:59 AM   #2
Kevin245's Avatar
Hi Daniel,
I noticed that you posted this same question on a DYI forum, are you dealing with a residential furnace system? Most furnaces used in RV applications are LPG rather than electric.
Kevin
Eleanor Roosevelt
Old 11-03-2010, 01:22 PM   #3
Originally Posted by Kevin245 View Post
Hi Daniel,
Kevin
Sorry I have no clue what the difference is. It was always referred to me as electric. Still no idea what a voltage regulator is. I have been searching forums and part stores online all day. I have yet to find a part named anything like that.
Old 11-03-2010, 01:29 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
You don't know whether you are dealing with a residential or RV furnace?
Vaughan
Old 11-03-2010, 01:42 PM   #5
It is a residential furnace. Sorry, I didn't realize that was the question. We are in a mobile home (trailer).
Old 11-03-2010, 02:22 PM   #6
Kevin245's Avatar
You might try Google searching "Intertherm FEH-012HA Troubleshooting". I came up with several hits, one of which is a forum specifically for Mobile Home issues.
Index page
Good luck,
Kevin
Eleanor Roosevelt
furnace blowing cold air canine camp Furnaces, Heaters, Fireplaces & Air Conditioning 55 07-26-2013 11:14 PM
furnace blows cold air only 99Limited34 Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-08-2010 08:49 PM
Little Furnace Wire Problems dan50w Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-25-2007 09:12 AM
Furnace blows cold air guy99 Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-06-2007 10:26 PM
Electric wire splice on magnets LI Pets Brakes & Brake Controllers 15 09-02-2006 11:45 PM
