Old 05-02-2009, 04:21 PM   #1
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Duo-Therm Thermostat out of calibration?
During the 4CU Vintage Restoration Rally in Albuquerque last weekend we started experiencing problems with the Duo-Therm Comfort Control thermostat. We used the heat pump and the AC at least once without issue but on Sunday morning I decided to warm the trailer up with the furnace and it wouldn't start. The inside temp was about 48 F so you would think a set point of 65 would work, but nothing doing. I then tried the heat pump again. Nothing doing there either. So we had a chilly morning. To get to the point, I got the furnace to work the next morning by upping the set point to 73 F (the trailer was ~48 F again). Moving the set point 20 degrees up or down demonstrated all systems working and pointed to the thermostat being out of whack. I speculated that the 50 MPH winds blowing dust around may have clogged the sensor but I haven't been able to get the front of the the thermostat off to check. That thing won't budge and I have a bad track record and a trail of broken plastic clips behind me. So first, does anyone know the trick to getting the front off the Duo-Therm? It must pop off. Second, has anyone seen this problem before? If so am I on track with cleaning it up or is it toast?
Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 05-02-2009, 09:00 PM   #2
denellen's Avatar
2007 25' International CCD
1964 19' Globetrotter
2012 Interstate Coach
vero beach , Florida
Thumbs down Thermostat; Standard Operating Procedure
STEP 1: Last 2 new Airstreams ( 06 & 07) both required extreme adjustments of thermostat to get operational. I'm saying, back it all the way down, then all the way up, then smack it with the palm of your hand.Keep messing with it until you finally get ignition. Once you reach a comfortable temperature, turn it off. Dont bother trying to set
it expecting it to automatically come back on when the temperature drops a few degrees. That wont happen.
STEP 2: Repeat STEP 1, or replace it with a BETTER unit.
Dennis
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
denellen is offline   Reply With Quote
Old 05-03-2009, 05:55 AM   #3
Images: 59
The cover may be removed by inserting a small screwdriver under the tab on the bottom edge of the front cover and gently prying. There's nothing under there that you can clean. The temperature sensor is probably a thermistor, which doesn't get plugged up.
Duo-Therm A/C on my Avion. 68 Suburban Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2009 11:20 AM
Duo-Therm Penguin A/C cooney Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-22-2008 07:55 PM
DUO Therm 115V, 60 HZ wlgilbert40 Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-02-2008 07:35 AM
Duo-therm heater harold1946 General Motorhome Topics 4 11-12-2007 05:08 PM
duo-therm not working toolman5252 Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-03-2006 11:24 PM
