Old 10-28-2010, 09:19 PM   #1
2003 25' Safari
Eden Prairie , Minnesota
Duo-Therm Question
I have a Dometic Duo-Therm Penguin heat pump in my trailer. The instructions say that when the outside air temperature falls below 30 F the digital thermostat will turn off the heat pump and turn on the furnace. Last night it got down to 22 F, but the heat pump continued to run and the furnace never came on. The heat pump was gradually losing the battle as the temp inside the trailer fell to 60 F with the thermostat set to 65. I eventually got up and manually switched over to the furnace.
There is supposed to be a temperature sensor connected to the thermostat to trigger the changeover. Anyone know where that is located? Ideas on how to troubleshoot?
Dan
dmac is offline   Reply With Quote
Old 10-28-2010, 11:06 PM   #2
dznf0g's Avatar
Oswego , Illinois
Hmmm..I have that setup and haven't read anything about an automatic switchover. Which manual did you read that?
Old 10-29-2010, 06:20 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Dan,
Try re-setting your thermostat. I have posted detailed directions on how to perform that operation, but I will include them here again:
1. turn off the thermostat (Dometic Comfort Control Center or CCC) at the bottom switch.
2. press in the top and bottom buttons on the CCC and hold them in.
3. turn on the bottom switch. You should see 'FF' in the window and it should be back-lit.
4. count to 5 and release the top and bottom buttons.
5. the CCC should be working normally now.
The auto change-over feature should now be activated. If not, PM me for further trouble-shooting.
Old 10-29-2010, 06:57 AM   #4
2003 25' Safari
Look on page 7, section "Aux Heat" of the manual at http://www.rvtechlibrary.com/heatair...tat_owners.pdf.
AUX. HEAT
When in the
HEAT PUMP mode, if the outside ambient temperature
is measured to be below 30F and the vehicle is equipped with a
furnace connected to the Comfort Control Center, the control will
automatically select the
FURNACE operation and the HEAT PUMP
will shut down.
Important:
If vehicle is not equipped with a furnace no heat
will be available below 30F. IF vehicle is equipped with a
furnace and it is connected to its own thermostat, it must be
manually turned ON and OFF for operation.
When this happens, the
AUX. HEAT and the HEAT PUMP indicators
on the LCD will illuminate. Once the outside ambient temperature is
measured above 38F, the control will return to the
HEAT PUMP
operation and shut down the furnace if it is connected to the Comfort
Control Center. If furnace is not connected to the Comfort Control
Center, the furnace thermostat must be manually turned off.
Dan
Old 10-29-2010, 07:00 AM   #5
2003 25' Safari
Originally Posted by lewster View Post
Dan,
Thanks for the hint... I reset the thermostat per your instructions. I will have to wait for more cold to see if it works! Is it a frquent problem that the thermostat "forgets" to auto-switch to the furnace unless it is reset? Anything I can do to help it "remember"?
Dan
Old 10-29-2010, 02:55 PM   #6
lewster's Avatar
If your furnace is operated solely by the CCC, then the switch-over should be ttoally seamless depending on the outside temps. That is assuming that the outdoor tempo sensor in the upper air conditioner unit is properly connected. If the CCC again fails to switch over to the furnace at low ambient temps, you might have this checked by any factory authorized Dometic service center who are familiar with this feature.
Old 10-29-2010, 03:54 PM   #7
dznf0g's Avatar
Oswego , Illinois
does anybody know if this has to be reset anytime the batteries are removed and reinstalled, or does it retain the programming?
Old 10-29-2010, 04:43 PM   #8
lewster's Avatar
YES!
The CC re-set should be done whenever 12VDC is removed from the trailer. That includes using the 'store/use' switch at the door in newer units.
Old 10-30-2010, 07:48 AM   #9
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
That's a good tip Lew. I didn't know that, even after you showed me how to do this in person. Are there any other signs of a needed CC reset during times that the heat is NOT running?
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 10-30-2010, 09:05 AM   #10
2003 25' Safari
YES!
Wow! I wish they put that in the instruction manual, or better yet a sticker on the thermostat.
Dan
Old 10-30-2010, 05:35 PM   #11
lewster's Avatar
That's why guys like me (even hough we are few and far between) make the BIG BUCKS!!!
Old 01-13-2011, 09:14 PM   #12
DAHarvey
2002 22' International
2004 22' International CCD
2010 25' FB Flying Cloud
Johnson City , Texas
Lewster, hopefully you can help me with my problem. I have a 2010 Flying Cloud Airstream with a AC/Heat Pump/Furnace and a 5 button CCC. Even after trying the reset I can not get Furnace to show up on the CC. I only have one zone. The heat pump works okay, but not hot enough. Any suggestions will be greatly appreciate.
daharvey is offline   Reply With Quote
Old 01-14-2011, 04:25 AM   #13
2008 31' Classic
Lake Charles , Louisiana
All of this is great/useful info. We have dual AC with heat pumps and I could not figure out why the furnace would not kick on when the ambient temp dropped too low. Now I know. And due to not using the AS as much as we would like, my batteries have been dead a few times. Thanks........steve
Steve & Mary is offline   Reply With Quote
Old 01-14-2011, 05:14 AM   #14
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Always good info on the forum...
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Diagnosing Duo Therm AC IndyAnne Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2010 11:49 AM
Replacing Armstrong with Duo-Therm question By the Bay Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-10-2009 07:38 AM
Duo-Therm A/C on my Avion. 68 Suburban Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2009 11:20 AM
Duo-therm heater harold1946 General Motorhome Topics 4 11-12-2007 05:08 PM
duo-therm not working toolman5252 Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-03-2006 11:24 PM
