Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-04-2003, 05:49 AM   #1
startrekker2001
startrekker2001's Avatar
Profile:  1978 31' Excella 500
Palm Bay , Florida
Images: 34
Duo-Therm Penguin odor
I had a Penguin installed in my 78 Excella recently and from the time I started using the A/C I have been getting a strong sweet smell from it. I am sure this is not normal. I only get it with the A/C, and not with the fan only option.
Any thoughts?
Vic Smith
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 07-22-2003, 08:22 AM   #2
BigDan
BigDan's Avatar
Profile:
I too have an odor from the air-conditioner in my 2003 CCD. Is there a remedy? Anyone.... anyone...
BigDan
2003 22' CCD
2003 1/2 Ton 4x4 Suburban
4.10 Rear
Honda EU2000i
BigDan is offline   Reply With Quote
Old 07-22-2003, 08:29 AM   #3
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I had a musty odor in my trailer, that I thought was coming from the toilet. Using an ozone generator would freshen the trailer up for a few days, then it was back. Finally traced it out to the air conditioner. My brother in law and I removed the shroud and cover off of the evaporator coil and gave it a good cleaning with a scented cleaner. Man was it filthy, and stunk a lot worse, when it was "right in our faces".
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 07-22-2003, 08:49 AM   #4
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
One thing that I do, besides clean it (when the time comes) is that about 15 minutes before I need to turn the A/C off, I turn it to high fan (NO A/C- compressor on) to evap most of the moisture on the coils. In some cars they found that molds and fungus can grow there causing odors. So far it's served me well on the cars and seems like an easy crossover to the Airstream.
Eric
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 13 02-09-2008 05:55 AM
? re Duo Therm Furnace - 1968 GT Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-21-2003 08:52 PM
Duo Therm Brisk Air JAG Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2002 08:29 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
