Old 07-12-2016, 07:24 AM   #1
1999 28' Excella
New Orleans , Louisiana
Duo-Therm Humming?
Our AC works great for a few hours then starts to hum and not work. After it is off for hours it works great again.
What is up with that?
badkat is offline   Reply With Quote
Old 07-12-2016, 07:40 AM   #2
Gainesville , Florida
If you are running it on low fan it could be freezing up. Try high fan.
Old 07-12-2016, 07:54 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Sounds like a bad starting capacitor on the compressor. When you say it hums and doesn't work, does the fan keep blowing, but the air is no longer cooled, or does the whole thing go dead and sits there humming until you turn it off? Does it throw a breaker when it is in humming mode?
Old 07-12-2016, 12:29 PM   #4
1999 28' Excella
It hums and no air is coming out. The fan is on auto. Guess I can try high fan. It does not throw a breaker. Actually at 2 am it was humming and it shut down humming before I turned it off.
Old 07-13-2016, 04:35 AM   #5
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Why does it hum? Because it doesn't know the words. Sorry, bad early morning humor.
I actually would think the humming is the compressor still running as the thermostat is still calling for cooling, with the FAN having quit on you.......... Fan motor may be failing, it may have debris in the fan housing causing it to "drag" some and get hot and eventually fail, or something along those lines.
Anyhow, it sounds as if pulling the outside shroud off and took a look (or having a trained professional do that) would be next. Be careful - on a ladder, on the AS if necessary, running the unit with the shroud off, all that can be dangerous.
Hope this helps.
ShinyPete is offline   Reply With Quote
Old 07-13-2016, 02:07 PM   #6
1999 28' Excella
The fan motor was replaced a couple of years ago. Last nite I put the thermostat on low fan and it cycled on and off and no hum. When it is on auto is when the humming comes on after a few hours of use. Fan seems to work great.
Old 07-14-2016, 03:22 PM   #7
Belegedhel's Avatar
Houston , Texas
I'll stick with my earlier suggestion--weak starting capacitor. I hae a similar problem with my AC. As long as it is running in "max-cool" mode, where the compressor doesn't cycle on and off, it is fine. If I let it run for a while (ie., compressor gets hot), then turn the "cooling" to mid range (where the compressor will start to cycle on and off to maintain the temperature), the first time it cycles off, it struggles to get started again (the dreaded HUMMMMM), and then the breaker trips.
Duo-Therm A/C on my Avion. 68 Suburban Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2009 11:20 AM
Duo-Therm or Coleman - which to buy ?? George Furnaces, Heaters, Fireplaces & Air Conditioning 7 04-15-2003 09:37 AM
Parts for Duo-Therm 900 series furnace? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-22-2003 02:45 PM
Duo Therm Brisk Air JAG Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2002 08:29 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
