Old 01-30-2011, 07:12 PM   #1
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Duo-Therm Comfort Control
Need one of these. Anybody have one?
Old 01-30-2011, 08:00 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
As you probably know by now, they are out of production. There is a 'fix' for them, as most of the failures occur in the control buttons on the board. There is a procedure to clean them and get it working again. I'll dig around in my files and see if I can find it.
As you probably also know, if it is not 'fixable' and you can't find a replacement, the only other option is to convert both of your Dometic roof units to a 5-button compatible relay control board and to change out your 4-button t/stat for a new 5-button model. This modification is a bit pricey, though.
thermostat, duotherm
swaybar gwag23018 Hitches, Couplers & Balls 6 01-30-2011 03:14 PM
Overlander Gaucho pics NicheVintage 1965 Overlander 11 01-28-2011 12:12 PM
duo therm heater "fire" kewpie Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-11-2011 10:36 PM
How to repair the control panel? DougZ General Repair Forum 1 01-10-2011 05:52 PM
Part # Duo therm penguin gasket? HCR Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-09-2011 12:27 PM
