02-15-2012, 10:12 PM
1966 22' Safari
Seven Valleys
, Pennsylvania
Duo-Therm CCC bad out of the box?
Installed a new Penguin 13,500 on the Safari, wired it up, hooked up the CCC, flipped the breaker &..........nothing. The CCC does not light or show anything. Checked fuse on board at AC, checked O.K.. Checked 120V there also. I have 12 volts through the phone cable at the CCC, sooooo is it bad out of the box? Sounds like a possibility from what others say about them. Any advise would be great at this point.
02-16-2012, 11:10 AM
1966 22' Safari
Seven Valleys
, Pennsylvania
Well, I gotta find out & the overwhelming response is killing me so new unit ordered off ebay. We'll see!
02-16-2012, 12:02 PM
Scary,
Usually I turn it off and on using the mode switch. My travelling partner uses the on-off switch that's hidden at the lower right corner. Causes lots of frustration.
02-16-2012, 12:29 PM
1966 22' Safari
Seven Valleys
, Pennsylvania
Thanks Mark, I cant even get the thing to light up or show anything on the screen.
02-16-2012, 01:02 PM
1981 31' Excella II
New Market
, Alabama
So what is a CCC?
Perry
02-16-2012, 01:22 PM
1966 22' Safari
Seven Valleys
, Pennsylvania
Comfort Control Center or fancy electronic thermostat that does not work.
02-16-2012, 02:58 PM
Wise Elder
2010 30' Classic
South of the river
Be sure you have the phone cable wired the right way. They do it backwards from the way they're wired for phones.
02-16-2012, 03:33 PM
1966 22' Safari
Seven Valleys
, Pennsylvania
Thanks Jammer. I'm pretty sure I have it right but will check.
02-18-2012, 04:42 PM
1966 22' Safari
Seven Valleys
, Pennsylvania
Rechecked my made up connections on the one end &had a bad connection remade it &it works! Guess I'm not as good of a cable end maker as I thought!
02-23-2012, 10:36 AM
Chatham
, Ontario
I own a 83 turbo diesel motor home and I am having problems with my furnace (can't get it to worrk) first I cannot even find the fuse to the furnace is it by chance in the fuse panel, checked all the fuses in the panel and they all seem alright have removed the wiring harness and it looks good, unfortuntely, electrical, my knowledge is very limited.Would sure appreciate any suggestions
02-27-2012, 07:02 AM
1966 22' Safari
Seven Valleys
, Pennsylvania
Sorry I cant help with furnace kenjoe...I dont even have one in my Safari! Try starting your own post to hopefully get a better response.
