Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-20-2002, 04:53 PM   #1
68 Suburban's Avatar
Profile:
Duo-Therm A/C on my Avion.
Much to my suprise when I turned on the original A/C unit on my 1968 Avion, it worked and blew COLD air. My question is, did these old units use the same R-12 freon that was used in the cars???
68 Suburban is offline   Reply With Quote
Old 10-20-2002, 05:49 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Most RV Airconditioners use the same stuff as a home one. I think that would be R22. The service ports, if there are any would allow for only the correct type of gauges to be attached. Now for the silly question. If it blows cold, why worry about the type of freon that makes it do so?
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 10-20-2002, 07:48 PM   #3
Profile:
Because it might need a charge in the future and I have a bunch of R-12 that I was going to get rid of. If it used R-12, I would save it
Old 10-20-2002, 08:09 PM   #4
Just a member
Images: 21
You have a small gold mine on your hands. Some AC shops charge 50 bucks a LB for the stuff, so check around you might be suprised at the potential windfall!!
Brett G
Old 09-06-2009, 12:20 PM   #5
Profile:  lancaster , California
I am about to cut a hole it the roof for the ac unit on 1967 avion c-10 can anybody tell me where to locate the existing wiring ? thanks
rommel is offline   Reply With Quote
Avion Pictures MarkCinCLT Our Community 1 12-20-2003 06:45 PM
? re Duo Therm Furnace - 1968 GT Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-21-2003 09:52 PM
Duo Therm Brisk Air JAG Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2002 09:29 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 11:11 AM
