DUO Therm 115V, 60 HZ
Hello, I have a AC unit that is 5 years old and was working properly last fall but after a 500 mile tow would not come on. Not the AC, fan, heater element, nada! I removed the inside shroud and placed a volt meter accross lines which seem to be going to the AC/fan switch and did read 115 volts. Before I start removing more things to check for broken/loose wires does anybody have any suggestions as to what it might be? It is not hooked up to a separate theromstat but has its on cooler reostat. The fan will spin freely. It may be the switch and if so where might I get a replacement? Thanks
