Old 06-01-2008, 02:13 PM   #1
Lake Lure , North Carolina
DUO Therm 115V, 60 HZ
Hello, I have a AC unit that is 5 years old and was working properly last fall but after a 500 mile tow would not come on. Not the AC, fan, heater element, nada! I removed the inside shroud and placed a volt meter accross lines which seem to be going to the AC/fan switch and did read 115 volts. Before I start removing more things to check for broken/loose wires does anybody have any suggestions as to what it might be? It is not hooked up to a separate theromstat but has its on cooler reostat. The fan will spin freely. It may be the switch and if so where might I get a replacement? Thanks
wallygilbert is offline   Reply With Quote
Old 06-01-2008, 05:32 PM   #2
grantb4's Avatar
2005 22' Safari
San Juan Capistrano , California
I've had some problems with mine and the repair was discussed in this thread (see page 2 and 3):
http://www.airforums.com/forums/f427...ool-33741.html
In a nutshell there are a bunch of fuses under the shroud on the roof. That would be a good starting point.
grantb4 is offline   Reply With Quote
Old 06-02-2008, 07:35 AM   #3
Thanks for the info. That's a good place to start. Wally
Duo-therm wall furnace - 1965 max7 1965 - 1969 Globetrotter 1 08-15-2012 10:53 PM
Duo-Therm A/C on my Avion. 68 Suburban Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2009 11:20 AM
Duo-therm heater harold1946 General Motorhome Topics 4 11-12-2007 05:08 PM
Duo-Therm 901 series jagcb750 Mechanics Corner - Engines, Transmission & More... 4 10-02-2007 12:35 PM
duo-therm not working bob arringto Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-03-2006 11:24 PM
