Old 07-08-2014, 06:34 PM   #113
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Thanks for the numbers, Terry. I admit that I like the looks of the ducted units, but surely wouldn't spring for a 2015 model just for this feature --- even if it just WHISPERED at me.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-08-2014, 06:56 PM   #114
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
I did it for the new tank sensors...
Hibby
Hibby is offline   Reply With Quote
Old 07-08-2014, 07:00 PM   #115
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by SteveSueMac View Post
Not so fast - decibels are perceived almost logarithmically. +\- 3db can be VERY noticeable...
Overlander63 - thanks for the numbers. How did it sound to you? Any perceivable difference?
It was much quieter in the bedroom area. I think part of any further perceived reduction in noise is because the noise is muffled, rather than a fan blowing.
Old 07-08-2014, 07:09 PM   #116
Well Preserved
1993 21' Sovereign
Originally Posted by Hibby View Post
Overlander, I just ordered a 30' FC bunkhouse. Please make up new data so I don't have to shoot myself.
I just call 'em like I see 'em.
Old 07-08-2014, 11:05 PM   #117
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by overlander63 View Post
Okay, I just performed the same test in the same location in the ducted 27, and the results may suprise some people.
Front (bedroom)- 50db
Center (under the a/c)- 61
Rear (dinette)- 57
Doesn't sound like that difference is hearable. I will post our relative results next week as well. Speaking with the region rep for AS today, I was told that the ducted also evens out the temperature inside the AS.
Old 07-09-2014, 03:52 AM   #118
Well Preserved
1993 21' Sovereign
That it does well. There are also now ducts in the lavatory area, so the bathroom is no longer stifling.
Old 07-10-2014, 02:05 AM   #119
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Images: 135
Well, it seems to be very quiet once the temperature is stable.... An amazing 60 dB. It is really not noticeable after a short time whereas the 2009 27 FB International A/C was very loud when it kicked in.
An interesting observation... Each unit sees to be delivering air to both ends of the trailer. I will investigate this more fully once power is restored here in Virginia Beach, Virginia....LOL
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 07-10-2014, 08:05 AM   #120
2012 30' Classic
Homosassa , Florida
On a 30' is there still an option for a second a/c in bedroom or does ducted system eliminate that option and if it is available is it ducted? Our 30' has two and I can't see any way one unit would cool sufficiently in hot humid Florida. Been there with a 25' and 13 didn't get daytime temps down to a comfortable level.
Tater is offline   Reply With Quote
Old 07-10-2014, 08:49 AM   #121
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I had 30amp only at Top Sail in mid May this year on my 30' bunkhouse...the 15K BTU AC unit pretty much had to run most of the time to get temp to 72-74 degrees, even with all awnings deployed (including streetside)...temps were not yet in the 90's at that point...no way jose, ya need two if you plan on camping in FL...esp once temps are upper 80's and above...now 80's and 90's back in my home town in VA are much more comfortable...never needed AC in our own home hardly growing up..fan in my window
PharmGeek is offline   Reply With Quote
Old 07-10-2014, 09:56 AM   #122
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
My new 2015 will have ducted air and 2 A/C units...
Hibby
Old 07-10-2014, 10:58 AM   #123
Durango , Colorado
My new 2015 27FB Serenity will have ducted air and 2 A/C units as well. The ducted air change for 2015 has no impact on the 2nd A/C option.
RVDreamer is offline   Reply With Quote
Old 07-10-2014, 12:04 PM   #124
2012 30' Classic
Homosassa , Florida
Thanks. I was wondering if it would be ducted. Two units are a good thing to have. Congratulations on your new A/Ss.
Old 07-10-2014, 06:51 PM   #125
Well Preserved
1993 21' Sovereign
Two a/c's are good with ducted air. You can run the one furthest away from you, and still get the cool air through the ducts. If it does get too warm, you can crank up the second one.
Old 07-11-2014, 12:26 AM   #126
Msmoto's Avatar
2007 25' Safari
Images: 135
As noted, one A/C in southern climates during intense summer heat is not adequate. My 2009 27FB had this problem. And the new system has two vents into the bathroom as was pointed out by Overlander.
What I have done is program the rear unit to go on at 8AM, off at 11PM. Thus, during the night only the front unit comes on, even quieter this way.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB
AIR #31871 K4MTL
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
