Old 07-06-2014, 11:02 AM   #99
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
OK, quiet, but more effective?
OK, I believe the ducted air is quieter if the dealers are saying it is. But, is the air distribution more uniform so that the thermostat gives a good temperature for the whole trailer with a single AC unit?
I have found, as have some others, that the front of the trailer stays much warmer than the rest of the trailer unless you use a fan to blow cold air to the front. The poor air distribution is worse than the noise.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-06-2014, 06:21 PM   #100
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by fmrcaptevil View Post
If my new Airstream is going to cost several thousand dollars more, I'd rather get a better grade of metal than 'ducted' air, for crying out loud.
What is it that you are buying ...or are you just offering your opinion?
Old 07-07-2014, 07:28 AM   #101
fmrcaptevil's Avatar
Weldon Spring , Missouri
A forum is a place where opinions on particular subjects can be exchanged.
You mess with me, you mess with the whole trailer park.
fmrcaptevil is offline   Reply With Quote
Old 07-08-2014, 01:44 AM   #102
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Gosh, I love. To give my opinion.... However, in a few hours I will be on my first trip with my new Serenity, and it will be hot in Virginia Beach, Viginia. In a few days I will try to post my impressions of the ducted air. While the unit was at the dealer pre-delivery it was sitting with the A/C being tested and seemed to be nicely cooled and with far less noise than I had remembered with my 2009 International Ocean Breeze 27 FB. Actually the AC was quieter than my Allegro Bus.
Back with my report in a couple days.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 07-08-2014, 10:16 AM   #103
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Can't wait to hear - either way you are going to have a blast in sure!
PharmGeek is offline   Reply With Quote
Old 07-08-2014, 10:33 AM   #104
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I just had a new a/c system installed in my home. It is much quieter and cooler than the previous antiquated system. The condenser fan and compressor are a lot less noisy. There is barely any noise inside the house. I feel the air coming from the supply vents with no noise. The evaporator is in the attic and the hall has acoustical ceiling tiles. The return grill is in the hall and there is barely any noise there- maybe a little wind sound- The neighbor still has his antique condenser. It sounds like mine used to sound-
When mine and the neighbor's are both on I hear his and don't hear mine-
Don't believe the sales hype about a newer and more efficient unit making your light bill less- my first light bill with the new unit was $151- about the same as it always has been-
The ducted system in our 2009 Forest River Wildwood LE 28RLSS was much quieter than the non-ducted systems in our 2013 Airstream Classic 30 Limited.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-08-2014, 10:47 AM   #105
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There is a 27FB with non-ducted air conditioning in the shop now. I took db readings at 4' off the floor at the front, rear, and directly under the a/c unit. The readings for it are:
Front (bedroom):52
Center (under the a/c unit) 60
Rear (at the dinette) 58
We have a 27FB with ducted a/c that is going to be available for testing later today or tomorrow. I will use the same measuring device, at the same elevation and locations in the trailer, and post those figures here when I get them.
Old 07-08-2014, 12:02 PM   #106
Durango , Colorado
Front (bedroom):52
That would be great.
After 8 pages of posts and multiple readings in non-ducted Airstreams, it would be nice to have at least one set of readings from a ducted Airstream.
RVDreamer is offline   Reply With Quote
Old 07-08-2014, 12:11 PM   #107
Well Preserved
1993 21' Sovereign
Okay, I just performed the same test in the same location in the ducted 27, and the results may suprise some people.
Front (bedroom)- 50db
Center (under the a/c)- 61
Rear (dinette)- 57
Old 07-08-2014, 12:17 PM   #108
m.hony's Avatar
2013 30' Classic
So much for ducted being quieter...
TAC #MS-10
Airforums #70955
Old 07-08-2014, 01:22 PM   #109
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
what year was the non-ducted 27FB?
Also, what device did you use?
Old 07-08-2014, 05:00 PM   #110
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
Overlander, I just ordered a 30' FC bunkhouse. Please make up new data so I don't have to shoot myself.
Hibby
Hibby is offline   Reply With Quote
Old 07-08-2014, 05:15 PM   #111
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Not so fast - decibels are perceived almost logarithmically. +\- 3db can be VERY noticeable...
Overlander63 - thanks for the numbers. How did it sound to you? Any perceivable difference?
Old 07-08-2014, 05:20 PM   #112
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I would caution conclusions until repetition by others forming more scientific consensus
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
