Old 03-22-2015, 05:13 PM   #491
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Originally Posted by m.hony View Post
Others just touch a button to fold or extend their mirrors. I have to do it manually. That's alright, though. I ain't fixinna buy nothin'.
I get mine out of front storage and hand mount them when on the road. Reverse when I park.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 04-22-2015, 04:23 PM   #492
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Of course,since I have a 2015 27 FB, I wanted to see if I too had an ac issue in the front. Indeed, I do. I'm in the desert checking it out. I have read that some folks are going to JC for ac angioplasty. Are we to assume that there is a blockage or that the new vent covers are the solution?
DoublTrouble is offline   Reply With Quote
Old 04-22-2015, 04:24 PM   #493
The funny thing is that I put directional closing vents on my 2000 SOB many years ago.
Old 04-22-2015, 05:41 PM   #494
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
In my case, I am assuming that there is a blockage as i have absolutely no air flow coming from the three vents forward of the air return on the street side.
Brian
SuEllyn & Brian McCabe
Old 04-22-2015, 07:05 PM   #495
Brian,
Thanks. I think that you're having the issue that I read about. Mine has some flow, significantly less on the curb side than street side. I am thinking that the adjustable vents will correct my issue. I am guessing you aren't looking at a 2000 mile one way trip to JC?
Old 04-22-2015, 07:14 PM   #496
moosetags's Avatar
You are correct. JC is about an 800 mile trip for us. We are on our way to Maine, so Jackson Center is not that far out of the way. Due to the complete blockage in our system, it may require removal of the interior ceiling skin. That is the kind of thing that I would be more comfortable having the factory do.
Brian
Old 04-22-2015, 07:36 PM   #497
Clearly a great option for you!
We have a guy whose father was a foreman on the line when Wally in LA. Today the son is the west coast guru. He is the main man for airstream when the dealers can't get things right!
Old 04-22-2015, 10:17 PM   #498
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by moosetags View Post
We have found on our 2015, the new shade can be half opened by putting the bottom shade rod under the two window control handles.
Brian
Yep...been doing that for years ... works quite well.
Old 05-02-2015, 05:36 AM   #499
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Has anyone else discovered the front vents put out little air while bedroom vents blow heavily? I am wondering if a production issue has allowed the front ducting to be somehow blocked, forcing all the air from both A/C units to be diverted to the rear.
Ms. Tommie Lauer
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 05-02-2015, 09:23 AM   #500
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I think the "weak" vents are just further from the unit or the ductwork has more bends. The "stronger" vents are closer to the unit or have less bends. How many vents are between the weaker or stronger vents?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-02-2015, 10:28 AM   #501
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
You could be right, M.Hony. However, in another thread Moosetags had their New Lucy's ducts repaired at JC earlier this week. They report that her streetside vents were not blowing. When JC removed the air conditioner from the roof and took a peek around, they found that some insulation had fallen down and obstructed things. JC repaired the issue and New Lucy's ductwork performance is said to be much improved.
Rocinante is our 2014 International Signature 27FB
Old 05-02-2015, 10:56 AM   #502
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Ms. Tommie Lauer
Moosetags posted that he was having issues with no air. Was going to the mothership for some work and this was one issue. The techs found some insulation in the duc work blocking the vent to the front of the unit, his is a 25'. It was in his tread about their trip to Maine, but was cut short due to a family emergency back home in FL.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-20-2015, 07:16 PM   #503
2015 30' FB FC Bunk
Golden , Colorado
I am staying at the Sycamore RV Resort outside of Chicago for the week and it is 43 outside. I have been running both zones in heat-pump mode and they are putting out a good deal of heat, however zone 1 in the bunk and bath area is blowing very cold air. I guess lack of insulation or no insulation between duct work and roof. This is quite disappointing to have the ducted air and having it blow cold in the back half. I guess I'll order the adjustable vents so the back ones can be shut off. Better than blowing cold. I guess it is still quieter even if it really does not distribute the heat well. While I did not notice it when we were in Phoenix in early April I guess the same thing will happen in reverse when the roof gets hot. Cold in the middle warm in the back.
Old 05-20-2015, 08:00 PM   #504
2016 30' Classic
Erie , Colorado
Sounds like the one heat pumps isn't pumping heat. Remember that heat pumps start to lose the battle at the 40 degree mark. And they will do a defrost cycle when the temps are between 30 and 42 degrees. Maybe it did the reverse for a period of time which is cold air. Page 10 in the Dometic Thermostat manual.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
