Old 12-08-2014, 09:41 PM   #421
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
This is the camera which the factory installed on my Serenity.
Digital Wireless Observation System featuring WiSight Technology
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 12-14-2014, 05:16 PM   #422
Remax gal's Avatar
2014 27' FB Eddie Bauer
Lake Placid , Florida
What did they have to do to install it? Looks like a fairly simply installation but then again...I know nothing about this type of stuff! It just says that it is easily transferred amount tow vehicles. Looking to buy this for my husband for Christmas so I can't ask him. Do you love it? I would appreciate any information you can give me! Thanks!!
Laura & Tom
Let the good times roll!! Laura
Remax gal is offline   Reply With Quote
Old 12-14-2014, 07:07 PM   #423
Msmoto's Avatar
2007 25' Safari
Images: 135
As I understand it the camera is wired to the running lights and works when the lights of the TV are on, which is always the case when i am on the road. You can see the camera mounted in the center over the window, and of course it requires a non-standard placement of the WBCCI number and logo.
WBCCI_Mayberry_10.03.2014 by Fantinesvoice.com, on Flickr
Any competent RV dealer should be able to install this. The monitor plugs into a 12v cigarette light outlet in the TV cab.
AIR #31871 K4MTL
Old 12-14-2014, 07:23 PM   #424
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
Laura, I have the Voyager 7 inch camera, WVOS713, I purchased from RVCAMS.COM they had the best price. $540. I had my dealer install the camera exactly as Tommie has shown in her post above. The dealer charged me 1 hour labor for the install. I love the camera, works great. Any questions call me you have my number. Russ
Russ and Lisa
2018 Classic 30
2015 F250 King Ranch 4x4 turbo diesel
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
Firedog1 is offline   Reply With Quote
Old 12-15-2014, 12:43 AM   #425
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We're also very happy with this camera, it's a fine choice.
Our dealer connected the camera such that it has power when the battery switch is in the "Use" position. As a result, we had them install a toggle switch inside the trailer that enables us to save battery power in camp by turning off the camera.
It would have been simpler if they had powered the camera via the running lights, as yours did.
Rocinante is our 2014 International Signature 27FB
Rocinante is online now   Reply With Quote
Old 12-15-2014, 06:54 AM   #426
Remax gal's Avatar
You are all awesome! Thank you so much for the info! My man is getting a Christmas present!!
Laura & Tom
Old 12-25-2014, 10:15 AM   #427
Remax gal's Avatar
How does the camera attach? Oh! Merry Christmas to you all!
Laura & Tom
Old 12-25-2014, 11:41 PM   #428
Msmoto's Avatar
2007 25' Safari
Images: 135
Although I have not examined it carefully, there must be a frame component behind the exterior aluminum so the bracket can be screwed into this reinforced part. I do not think just screwing it into the exterior skin would be adequate.
I will try to check this out, but have no real way to determine if there is a frame rib behind it.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
AIR #31871 K4MTL
Old 12-26-2014, 06:34 AM   #429
Remax gal's Avatar
Thanks!
Laura & Tom
Old 12-26-2014, 03:54 PM   #430
Msmoto's Avatar
2007 25' Safari
Images: 135
After looking at the bracket for the camera, it appears the exterior skin of the AS is stiff enough in this area, curved, so as to provide substantial support for the bracket. The top edge of the bracket is about 6 1/2 inches below the rear edge of the middle marker lamp. The wire to power the camera enters the space between the AS skins at about 4 inches below the marker light. Presumably this wire obtains power and ground from the wires feeding the middle marker light.
There is no evidence that a rib exists beneath the skin as no rivet line is noted.
Good luck.
AIR #31871 K4MTL
Old 12-26-2014, 04:39 PM   #431
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The factory service center and dealers mount the cameras in the general vicinity of the roof clearance lights. There must be structure there, or else the skin is really stiff. The curved end segments are a thicker aluminum than the straight side panels.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-26-2014, 10:50 PM   #432
2016 30' Classic
Erie , Colorado
Camera is only mounted the skin if they used screws. Can also be attached with VHB tape and then Sikka 221 covering everything. If a hole is drilled for the power the installer just need to hook the power wire going up to the center running light and tap in.
I always manually turn on my headlights, that powers up the camera. Also a double check if I don't have a signal on the screen either I didn't turn on the headlights or worse forgot to plug int the trailer connector.
You can look at the end cap drawings on the parts manual for your trailer and see all the rib locations.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 12-27-2014, 08:51 AM   #433
Rivet Slave
Rocinante's Avatar
Perhaps we can just ask the dealer how they install it.
Btw, the Voyager is on sale at camping world right now.
Old 12-28-2014, 03:25 AM   #434
Msmoto's Avatar
2007 25' Safari
Images: 135
Just a note on "ducted air"... My bedroom unit seems to blow much, much more forcibly than the front living room unit on the same fan speed. Also, the road side outlets blow 2 or 3 times more air than the driver side outlets. Has anyone else experienced this on a 30 RB unit?
Ms. Tommie Lauer
AIR #31871 K4MTL
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
