Old 10-18-2014, 09:41 PM   #393
mefly2's Avatar
2015 25' FB Eddie Bauer
Was this temperature differential also an issue with the non-ducted two AC units? If so, what was done to resolve?
Old 10-19-2014, 02:02 AM   #394
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
In their infinite wisdom, Airstream often mounts the thermostat on the refrigerator cabinet wall.
But it is mounted after they have drilled a hole through that wall for the wires to come through. They do NOT seal that hole, so the ambient air temperature hitting the back side of the thermostat and wafting into the sensor reflects the heat of the propane flame cooling the refrigerator or the cold of the space when using the electricity for that function. That space is vented directly to the outside with one or two louvers for air movement.
We put the thermostat on a new mounting board for some insulation from the refrigerator wall (see avatar) and sealed the wire hole with some insulation stuffed in the hole covered with aluminum tape in the refrigerator space.
This brought the interior reading at that location more in line with the bedroom sensor.
Old 10-19-2014, 05:20 AM   #395
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
Switz,
That makes sense, I will give it a try! You wonder why someone at Airstream does not think of this. Thanks! Mark
LaBigDogs is offline   Reply With Quote
Old 10-19-2014, 06:29 AM   #396
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Both of my sensors are mounted close to the LCD TV's and the heat from the TV effects the sensor- makes the trailer cooler in the summer and colder in the winter-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-19-2014, 06:44 AM   #397
Gainesville , Florida
Can't you just adjust the thermostat to compensate for the placement of the senders? Jim
Old 10-19-2014, 10:30 AM   #398
dcopps's Avatar
2015 27' Flying Cloud
1984 31' Sovereign
Kingwood , Texas
With the temp sensor mounted on a warm wall, it causes the a/c to cycle much more often to compensate. It takes less than a minute to warm the sensor back up where it trips on the compressor. I will either move it or insulate it from the wall.
Dan
dcopps is offline   Reply With Quote
Old 10-20-2014, 10:15 AM   #399
mefly2's Avatar
Sure makes sense - even with only one thermostat ...as that is just where it is mounted for us, too!
Old 10-20-2014, 11:06 AM   #400
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My thermostat in my 2008 Classic FB is on the shower wall in the bedroom which causes the bedroom to be cooler/warmer than the rear living area.
Does the ducted air cool the bathroom well? I hate going into a hot bathroom during the summer months. We can't really leave the bathroom door open as it restricts movement in the hall way. At least there is a furnace duct in there for cooler weather.
I was talking to a 5th wheel owner this weekend and mentioned Airstream finally started putting ducted air in the 2015 and he kinda snickered asking why it took them so long. I've never owned an RV with ducted air so I guess I don't miss it. He did mention however, that the bedroom area in his 5th wheel didn't cool down as well as the rear living area. The ducts in the living area are pretty high up in a 5th wheel so they would be hard to close off without a stool.
Kelvin
Old 10-20-2014, 06:37 PM   #401
lewster's Avatar
Naples, FL , Hood River, OR
For sure, Airstream was very late to the ducted air party. All of the other RV manufacturers have been doing it for years.
But then, they always had more than a 2" roof thickness to work with!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-20-2014, 08:40 PM   #402
LaBigDogs's Avatar
Took care of the heat form the TV rising up into the thermostat today. Relocated the thermostat near the light switch. 28"LCD above the S/W and thermostat.
Old 10-20-2014, 09:47 PM   #403
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
As to the bathroom query...on my 30 RB Serenity there are two outlets in the bathroom...nice and cool in the summer, warm in winter.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 10-20-2014, 10:26 PM   #404
mefly2's Avatar
Kelvin
Very well, indeed, in our 25.
Old 10-21-2014, 08:20 AM   #405
switz's Avatar
2014 31' Classic
Images: 8
Back in the day, there was an adjustable compensator in the circuitry of better quality thermostats one would adjust to the setting recommended by the furnace/air conditioner manufacturer.
However, the Dometic and Atwood equipment is not built to those standards.
Old 10-27-2014, 06:55 AM   #406
lewster's Avatar
Yep. It was called an ' anticipator' and allowed you to set the number of degrees before the t/stat would kick back on or shut down, depending on the temp. settings.
The new electronic units from all if the RV HVAC manufacturers are pre set to around two degrees and can't be adjusted.
Lew Farber
541-490-6357
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
