Old 09-18-2014, 09:10 AM   #309
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
Originally Posted by Msmoto View Post
I agree, I do not see any real "hump" and that is why I think they did an excellent job in the design. As one can see from the photo of my unit in my garage, the "hump" is not really visible. Photo taken from about 7 feet off ground.
I wanna garage too
Sooooooo jealous!!!!
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Old 09-18-2014, 01:36 PM   #310
mefly2's Avatar
2015 25' FB Eddie Bauer
Humps and zones ...???
As I said before, there is an almost imperceptible hump both fore and aft ...
Whew, with all of this hump-ing, I am beginning to get zoned out.
We have only one AC and are glad to have the full length ducting ... the longer 2015 unit we looked at with dual AC units still fed into just one duct and distributed conditioned air throughout the entire trailer. I am not sure why you would want to mix AC cooled air with heated air from the furnace unless for dehumidifying.
We have found that a great deal of moisture and foul smell comes out of our overhead ducts when the heat pump is first turned on the morning following use of the AC. So, in the future, I will continue with fan only for a bit after the AC compressor shuts off.
WE really like the ducted air and would not want to go back ... we have not used the 12v or 110v aux fans even once in the new ducted unit * but used them regularly before ... wanna buy a fan?
Old 09-18-2014, 01:39 PM   #311
2015 30' FB FC Bunk
Ayer , Massachusetts
Does the heat use the ducted air or just the AC? For reference, I have (ordered) the 2015 30' bunkhouse.
That would be sweet if the heat uses it as well.
Ted S. is offline   Reply With Quote
Old 09-18-2014, 02:25 PM   #312
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
The heat pumps when on shore power use the ducted ceiling vents. The furnace, when dry camping uses the same near floor wall mount vents.
Of course, if the outside temperature approaches 25° F, the use of the heat pumps becomes limited. I believe the manual suggest 12 hours max with the heat pumps at ambient temps of 25° F.
You will love your new Airstream, i am certain.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 09-18-2014, 02:32 PM   #313
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
yeah, I am not impressed with the "hump"...seems pretty much based on the colonial videos as well not even noticeable.
PharmGeek is offline   Reply With Quote
Old 09-18-2014, 02:41 PM   #314
Durango , Colorado
I doubt if Airstream will change this design. The only time the hump is visible is if you are on the roof. Otherwise you can't see it.
Who cares how the roof looks. There are already vent pipes, fan covers, sunlights, antennas, A/C units, solar panels, etc. etc. No one should be bothered by a hump up there.
RVDreamer is offline   Reply With Quote
Old 09-18-2014, 07:39 PM   #315
mefly2's Avatar
It is nice to have two sources of heat for both shore power and away...via the 110VAC heat pump /AC and the propane fueled furnace.
The design is great; hump or not ... whether it is visible to you or offends, is in the eyes of the beholder. There is a hump at each end; but, you can't please everyone. Why would AS need to re-design the entire TT line above 25' just to get rid of the innocuous hump? Lots of speculating by folks that haven't even picked up their 2015 or actually listened to the ducted (or looked at printed sound pressure level comparisons) --- let alone voted with their checkbooks. First it was the sound levels - now the hump ...
If it sounds like I am defending the design (and our choice thereof), you are correct. We really like, like, like the ducted. As my dearly departed Father used to say, don't cheap shot or knock it until you try it!
However, everyone is entitled to present their opinion - all 23 pages so far!
Old 09-18-2014, 07:43 PM   #316
2015 30' FB FC Bunk
Considering I never owned an Airstream before, I wouldn't even know some of them are humpless.
I just think the innovation is really cool.
Old 09-18-2014, 08:05 PM   #317
mefly2's Avatar
Originally Posted by ted s. View Post
considering i never owned an airstream before, i wouldn't even know some of them are humpless.
i just think the innovation is really cool.
lol
Old 09-18-2014, 08:36 PM   #318
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
I'm all in favor of ducted air. Saw one at the dealer, thought it was a great improvement. Wish we had it.
Won't be buying one just now.
We've barely broken in our 2014 model, having spent the last 10 months making trips to the dealer to get all the fit & finish warranty issues resolved, some pretty serious. Those were boo-boos and blunders that never should have left the factory. I'm not eager to take *that* project on again for at least a few more years. On the plus side, when we take delivery of our next new AS, our experienced eyes will probably spot so many issues that the dealer will have to keep the trailer on his lot for the first couple of months to fix everything before we're willing to take it home.
Separately, I was idly speculating that given this is the first model year for ducted air, AS may make further improvements (not just changes!) to that feature in model years to come. I certainly wasn't passing judgment on a roof hump or lack thereof.
Old 09-19-2014, 05:13 AM   #319
Msmoto's Avatar
2007 25' Safari
Images: 135
I wanted to emphasize the issue of fit and finish. I believe there is no final inspection process at Airstream, or if there is, they are using folks who have a poor attitude. I have not been able to get the vents out of the ceiling and in the bedroom on mine the air blows in my face when I am in bed.
BTW, the 27 FB is one of my favorites, and I would have gotten this model again except I wanted the larger water tanks in the 30 footer.
AIR #31871 K4MTL
Old 09-19-2014, 05:53 AM   #320
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
If you really want your new Stream ZONE Ducted, all one would have to do is pop off the vent where you want it zoned and stuff something in the duct where you cant see it to block the air. Now you have a customizable Zoned system, and the great news is you can change it anytime you like.
LaBigDogs is offline   Reply With Quote
Old 09-19-2014, 07:35 AM   #321
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Sounds like the only people who will be aware of the hump is the owner when they wash the roof and the truckers on the highway.
I'm sure you will impress a lot of the trucker's when you go past them they will say "there goes one of new humped airstreams with the ducted air. I'll have to get one of those someday!"
The duct system should have been installed 25 years ago - what took them so long!.........
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 09-19-2014, 09:41 AM   #322
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Fit and finish are the major issues we are addressing all the time. Building units too fast results in extremely poor attention to detail. There is just not enough time to do it right so the user gets to make uncountable trips to fix things that should never have left the factory.
Typical brain fart issue in our Classic. We have four fluorescent light fixtures on the ceiling in the hallway that use 12" bulbs. There are two also attached under the front roof locker and over the sink. The latter two are flat surfaces. The roof is arched with a radius and the fixtures were screwed down tight putting a slight bend in the fixture. The lenses were forced in and thus cracked in the center where there is less distance between the sides than at the edges due to the slight curvature.
I now have four replacement lenses that I will have to carefully sand to fit as the dealership lacks competent folks that I would trust to do the job as they would be in a hurry as well.
switz is online now   Reply With Quote
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
