Old 09-09-2014, 12:39 PM   #267
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
When I get another 50 amp shore cord, I intend to leave the other one at home- lying permanently behind the shrubs, so all I have to do at home is pick it ip and plug it in.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-10-2014, 01:52 PM   #268
Dallas , Texas
Question for those of you with the new ducted system. Seems everyone agrees it is much quieter than the standard a/c.
But since it is a "cooling" system after all, and given the ducting is made of heat-conductive aluminum and is routed between two aluminum skins with some insulation, how does it cool? Is the single 15K unit sufficient for the 25/27ft trailers? And if you have not actually camped in hot climates, maybe some of you have tested the system at a dealer's lot when it was fairly hot/humid outside and can chime in.
I realize cooling is a relative measure and is directly related to the outside temperature. But since I live in Texas, a/c is very important.
Thanks, John
neck101 is offline   Reply With Quote
Old 09-10-2014, 03:11 PM   #269
mefly2's Avatar
2015 25' FB Eddie Bauer
Thanks, John
This Again! Did you read the preceding pages?
Based on 51 days out in the AS this season and 21 with the new ducted ...Yes, the single AC cools very efficiently in 95-100 degree temps in our 25' Eddie Bauer ... both with and without shade and both in campgrounds and the dealership lot. It is SIGNIFICANTLY more even cooling than previous models. We have not needed additional fans to "redistribute" the cold * or heat - as we now have temps hovering around freezing.
We have two fantastic fan openings and a skylight - in addition, there is also an Eddie Bauer metal vented opening at the front (and also rear side).
The additional insulation is a plus and quite noteworthy as mentioned before. I have no idea just what your ambient temperature is and whether you want advice on a 25 or 27; they are different.
Better than taking a stranger's word for it, may I suggest that you visit your local dealer and see for yourself.
Old 09-10-2014, 07:57 PM   #270
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Yesterday, we converted both air conditioners to the prior version of condensate pan and the noise reduction was very noticeable and it seems to cool more effectively. We tossed the two dinky plastic condensate catch cups on each unit that rattled against the outer skin.
Today, we started the air conditioner at 102 outside with no shade in high humidity Dallas area. In about 40 minutes the trailer was cooled down to the high 70s.
Old 09-10-2014, 08:24 PM   #271
lewster's Avatar
Naples, FL , Hood River, OR
Just another example of Airstream 'paddling against the tide' from the rest of the RV industry! They use a single A/C gasket now when using the Dometic aux. drip kit when the specification from Dometic is for TWO gaskets! This raises the drip cups off the roof so the DON'T RATTLE and are not sandwiched between the roof and the base pan of the A/C unit.
Funny, how everyone else in the industry has no problems with the drains of their A/C units........except Airstream!
Old 09-10-2014, 09:59 PM   #272
Dallas , Texas
Wow...guess I drilled into a healthy nerve!
I did read the previous 5 pages and all I saw was one report with the outside air temp being around 86 degrees and 78 degrees inside....I was simply looking for more replies, especially in hotter weather.
I realize ducted a/c alone will increase circulation...just wanted to know if the aluminum skin on top of the ducting was significantly affecting the temperature of the cooled air at the outlets. I agree the insulation should help. But never having owned an airstream, I notice that a common complaint is the hot/cold inner skin due to limited insulation.
As to my 25/27ft query, I have noticed that most of the 2014 and earlier 27 footers had 2 a/c systems, while many of the 2015s have only one. That in itself would lead me to believe the new system is more efficient.
And yes I will be checking out dealer units at the Dallas RV show this weekend. Only "problem" is we will have much cooler weather and therefore I probably won't get an honest test.
Old 09-12-2014, 11:30 AM   #273
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
It will be interesting after a period of several months if we find out the ducted A/C is so much better that the second unit is not necessary for the vast majority of units.
An interesting phenomenon is that so far from my experience, when the Zone 1 is on, the most air flow is in the bedroom, and Zone 2, more is up front in my 30 RB. Also, there should be a fix to the outlets in the bedroom so they do not blow in one's face when the fan is running at any speed.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 09-12-2014, 07:21 PM   #274
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
In my 25 there is no need for zones. It works great and is considerably quieter.
I love it.
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 09-13-2014, 02:58 AM   #275
m.hony's Avatar
2013 30' Classic
We need zones.
I'm always freezing.
My wife is always burning up.
We need 2 televisions.
I'm more "This Old House".
She's more "Dancing With the Stars".
TAC #MS-10
Airforums #70955
Old 09-13-2014, 07:11 AM   #276
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
The good news, is I bet there will be aftermarket owner installable operational, diversion, and flow control, vents to replace the lent catching screen, that is used from Jackson Center. If your inventor you could make a few bucks....
1. Must be out of aluminum with a clear coat.
2. Attractive.
3. Simple.
4. Cost efficient.
5. Direct the air to where you want it.
6. Close down or close off the vent air flow.
Simple.... I will purchase a set!
Now you can have your 2015 A/C Zoned... very simple.
LaBigDogs is offline   Reply With Quote
Old 09-13-2014, 07:48 AM   #277
2012 30' Classic
Homosassa , Florida
If you have two units you can leave one off. If you have one unit and need two you have a problem.
Tater is offline   Reply With Quote
Old 09-13-2014, 07:52 AM   #278
LaBigDogs's Avatar
Thats is why I have two.... for the extra hot days.....
Old 09-13-2014, 08:22 AM   #279
m.hony's Avatar
2013 30' Classic
I'm cold. I'm running the heat pump up front.
My wife is hot. She's running the air conditioner in the back.
You can't do that with one unit.
For me it is moot/not a point of contention. I already have the trailer and it already has 2 a/c units.
Most dealers in the south order the units for inventory with 2 a/c's.
TAC #MS-10
Airforums #70955
Old 09-13-2014, 06:49 PM   #280
lewster's Avatar
If you have a single Dometic CCC-2, I don't believe that it will allow you to operate separate zones on heat and cool from the different roof units.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
