09-25-2014, 09:00 PM
#361
2013 30' Classic
Kent
Huh? Run that by me again?
Originally Posted by ghaynes755
Was just in the first 2015 Classic that was sold up at Gillette. With both AC's running you don't have to shout. It is considerably quieter. A decibel meter might tell a slightly different story so some of this lessening of the jet engine sound of the stand A/C might be the damping and different tonal range of the sound (if that makes sense).
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
09-25-2014, 10:25 PM
#362
TinCan
2016 30' Classic
Apache Junction
I think my second question was answered. You can run on 30amps with a adaptor kit? If so that is a good idea. Can't think when I really would need 50amps unless running 2 AC's.
TinCan
09-26-2014, 12:19 AM
#363
2020 Classic 33
Box Elder
, South Dakota
There were previous posts in the thread that a decibel meter had been used and the readings were very similar ducted vs non ducted. What I was trying to say is that the empirical scientific numbers might be correct but the my perception is that the ducted system is much quieter. That perception may be based on the tone of the air from the ducted system. It is a lower pitch than the non ducted.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
09-26-2014, 02:21 AM
#364
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro
, North Carolina
The sound level is highly subjective. However, when using the rear a/c and sitting in my recliner up front, the sound level is not noticeable. Maybe the two a/c units in combination with the ducting makes the units quieter. Whatever it is, IMO, ducted a/c is appreciably less intrusive.
At night, in bed, the decibel meter is around 50, less than human conversation. I do not remember my 2009 Int Ocean Breeze 27 FB ever being this quiet.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
09-27-2014, 10:31 AM
#365
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
The sound pressure level is empirical with regard to measurements - quantified from the same device at the same location in the same trailer model and length; ducted vs. non-ducted ...go back and look at my comparison numbers; I posted them several times. The higher velocity air from the single exhaust vent produces a higher pitch in the non-ducted system. The ducting reduces the velocity from each of the several outlets and results in a lower pitch. That's my evaluation and perception and I am sticking to it. YMMV
10-09-2014, 09:46 PM
#366
phoenix
After fulltiming in my 2015 30ft International I can say that the two ACS with ducting keep it very comfortable in Texas even with the high humidity. I think it's pretty quiet, but I have nothing to compare to... I will say everyone seems to be surprised that it can actually feel cold in here even though the lowest I usually have it set is 78 on auto. And yes, so much for zoning, but I can turn on only one AC at the opposite end at night when it doesn't have to work so hard if it's too loud (though I like the noise for sleeping).
10-09-2014, 10:19 PM
#367
Durango
I don't know how many have seen this but I thought I would upload the file so that others could learn more about the new ducted A/C
10-10-2014, 02:40 AM
#368
2007 25' Safari
Greensboro
, North Carolina
I have now had about three weeks in my new Serenity and can suggest the comfort level of my Airstream is the same as my Allegro Bus, a very sophisticated Moho. In fact in some respects the A/C is better as the diffusion of cooled air is excellent other than the draft on the bed when running on a fan speed other than Lo.
Ms Tommie Lauer
Greensboro, NC
AIR #31871 KQ3H
10-10-2014, 06:54 AM
#369
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We have now had the 2015 25FB for a week. We have spent a lot of time in it setting it up. It is still hot and humid in the Florida Panhandle. The new ducted air conditioning works great even though four of the vents have no air coming from them.
It is absolutely significantly quieter than unit that we just traded in our 2012 23FB. I can actually hear the television or radio. We can also hold a normal tone conversation in the trailer while the air conditioner is running.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
10-10-2014, 07:33 PM
#370
2007 25' Safari
Greensboro
, North Carolina
Four vents with no air….? Are these round or rectangular? The rectangular vents are the return and have a filter behind the grill. The round vents are the cool air supply.
AIR #31871 KQ3H
10-10-2014, 07:54 PM
#371
Durango
Moosetags,
Look over the pdf file I uploaded in the post above. It shows a diagram detailing the vents that supply cool air and the vents that are return air.
As Msmoto says, four of the vents are return air.
10-10-2014, 08:09 PM
#372
Santa Rosa Beach
Originally Posted by RVDreamer
Moosetags,
Thanks much for that info and the diagram. I'll recheck my system in the morning.
Brian
10-10-2014, 09:34 PM
#373
2006 25' Safari
St. Augustine
RVDreamer, thanks for the read. Ever since the "ducted air" hit the forum I have been reading anything I can find about RV air conditioning. I have modified my traditional unit from original and it improved my experience considerably but it is nowhere near the change of a ducted system.
I believe time will tell on the questions raised on this thread. Naturally those that are buying it are in support and hoping for the best. The important thing to remember is that ducted air is not new to the industry. After looking over the Airstream design piece RVDreamer posted, it is really not any different than other systems out there, just applied to an Airstream.
From reading about "basement air" and other threads on "ducted air" I believe that the main reason for the second AC unit follows how many class A owners have described the ducted experience using a non-ducted unit or in some cases closing the duct to cool the space down first, then using the duct to run more continuously. In some setups it is described as having one ducted AC and one non-ducted AC. The noise factor is apparently highly subjective overall. What I found under Class A reads is that owners can turn the fan to low on the ducted model but that cooling ability is greatly reduced and cannot be sustained in warmer temperatures. The idea though is a good one because it provides options.
Oh, and on the basement AC, I read where it was the quietest; however, there were cooling issues that some companies had abandoned the design. This seemed odd to me as tour buses still use it. Still, someone is going to come up with more good ideas for cooling RVs!
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
10-11-2014, 05:09 AM
#374
2007 25' Safari
Greensboro
, North Carolina
Oh, more confusion on how the new A/C works…. So far, Zone 1 is in the rear, the actual HVAC unit that is, but seems to blow more air into the front. Also, the Zone 2 Unit, is in the front, but blows more air into the bedroom (rear). Casual observations only. And, some of the round vents do not seem to blow a lot of air, the two over the bed, maybe a bit excessive, although if one likes to sleep with an overhead fan, this is great. More observations on this to be made.
It would seem that if one were willing to give up about 1 1/2" of headroom, a "ducted air" system could be configured from the older A/C units, using sheet metal of other thin material, closed cell foam to dampen the noise, and very thin ducts, roughly 1" in height. Maybe someone will come up with a "kit" to do this on some of the pre 2015 units.
AIR #31871 KQ3H
10-11-2014, 07:44 AM
#375
Naples
I the RV industry, RVP Coleman made the 'package' units that were mounted below floor level. Winnebago was the largest used of these units, but they were also used by Damon, Alfa Leisure (now deceased) and several others. Alfa even put them in 5th wheels.
RVP discontinued these units about 3 years ago. They were an incredible PIA to work on as the 300 lb unit had to be dropped to access the interior.
Over the road busses use a different system.....mostly the Cruise Air units that were originally built for yachts. These are bullet-proof units that are totally serviceable while in place, but are hugely expensive.
The RV industry found the disposable roof units to be far easier to install, cheaper to buy and generally better for the bottom line.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
10-11-2014, 02:34 PM
#376
Santa Rosa Beach
Moosetags,
This morning I got a chance to further assess the air conditioner duct situation in New Lucy. The diagrams you provided helped immensely.
New Lucy is a 25FB. She has two rectangle shaped vents in the ceiling midway in the trailer. I verified that these are the return air vents using a paper towel while the unit is running. Lucy has six additional vents on each side of her interior. Three forward of the air return vents and three aft on each side.
All of the vents seem to blowing air except the three forward vents on the street side. These do not blow any air at all.
Brian
10-11-2014, 03:55 PM
#377
Durango
Brian
I wonder if you have an obstruction in the main duct to the front on the street side. Is it possible to remove a vent cover and use a fish tape to see if there is blockage in the duct?
10-11-2014, 04:03 PM
#378
Durango
Most of this issue is probably just pressure differences in the duct. I would think it would be easy to tune this system by putting folded cardboard obstructions in the ducts at key points.
For example; You could make it harder to blow air to the back bedroom vent by placing a partial obstruction into the main duct to that side.
10-11-2014, 05:41 PM
#379
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Sounds like you've found your first warranty repair issue on new Lucy. I'll bet they somehow messed up the ductwork. This may not be new tech, but it's new to the AS build teams.
Brian
10-11-2014, 10:21 PM
#380
Small Town
Brian
Time to see a service tech ... all of our outlets blow cold when on AC and very warm when using heat pump. The rectangular inlets have filter material behind and respond well to light vacuuming.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Ducted Air
Bassrats2 |
Furnaces, Heaters, Fireplaces & Air Conditioning |
5 |
04-27-2014 05:52 PM |
Non ducted VS Ducted
ianburnett |
3 |
12-01-2012 11:24 AM |
Ducted or Non-Ducted A/C
tesstoaster |
2 |
06-22-2012 01:43 PM |
Ducted AC
chetos |
19 |
12-13-2011 09:29 PM |
Cool air ducted from below trailer
truckasaurus |
Roof Vents, Skylights & Fans |
8 |
03-05-2009 09:35 AM |
