Old 08-18-2014, 10:15 PM   #197
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by lewster View Post
On changing many of these units for replacement, I have found that over zealous techs or line assemblers routinely strip one or more of these mounting holes, creating a loose mounting situation which luckily can be remedied by the use of a larger diameter bolt or lag.
If any of these new A/C units fail in short order, be aware of this situation and be certain to inform those performing the repair about the possibility of over-torqueing the mounting bolts and stripping them. To not do so will certainly invite leaks thru an improperly compressed sealing gasket.
Excellent advice, Lew. We have already experienced stripped out lag bolts in the rear anchor points of our EB ... not to mention stripped out fasteners in the sidewall mounting of electrical receptacles. What is next!
Old 08-19-2014, 07:58 AM   #198
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Trying to crank 51 units out per day means each job is timed for speed with accuracy of work forgotten. Something not done is not rectified unless it "shows".
I watched the chap putting the black sealer on the edges of the plywood. As the brush emptied, one could see through the stuff and there was no reswipe to fill in the these areas.
It is really not surprising we have the issues we do because of the "rush" for more profit mentality versus do it right no matter what.
Obvious external trim issues were personally pointed out to the QC supervisor both in person and a photo in an email. Those issues were still there when the trailer arrived at the dealership.
switz is online now   Reply With Quote
Old 08-19-2014, 11:23 AM   #199
lewster's Avatar
Naples, FL , Hood River, OR
I believe that's 51 a week.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 08-19-2014, 12:52 PM   #200
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If they are able to sell 51 a week the company must be very financially sound.
That's roughly 2,500 trailers per year.
That would be about 50 sold in each state. We know that isn't the case. Does Airstream have a huge overseas market? I know some are sold in Canada. I wonder how many are sold in each country or state.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-19-2014, 08:38 PM   #201
jkfinephoto's Avatar
2015 30' International
phoenix , Arizona
Heading to pick up the 30ft with the dual acs, will give a full status report after our trip home from Portland so excited!!!
jkfinephoto is offline   Reply With Quote
Old 08-19-2014, 08:48 PM   #202
2016 30' Classic
Erie , Colorado
They expanded last year (?) into the far east and what I heard at the factory in the spring was business is booming in China and the other markets. And the 2500 number sounds about right.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-20-2014, 03:52 AM   #203
m.hony's Avatar
2013 30' Classic
Of the 2500 about 3 were sold in Mississippi?
TAC #MS-10
Airforums #70955
Old 08-20-2014, 05:19 AM   #204
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
Jkfinephoto,
Congratulations on your new unit, hopefully you will have many years of enjoyment and making many memories .....
Enjoy.
Nelson
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 08-21-2014, 05:22 AM   #205
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
jkfinephoto _ Congratulations.... you are now the owner of the QuietStream! Enjoy!
LaBigDogs is offline   Reply With Quote
Old 08-21-2014, 09:17 AM   #206
mefly2's Avatar
Likely about the same for MT as far as new ones ...
jkfinephoto ...keep us informed as you journey home...
Old 08-21-2014, 10:12 PM   #207
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
One more first hand report
We camped next to a 30 foot 2015 Classic last week, and were given the tour. The A/C does seem quiet compared to my 2013 25FB.
It seems that space for the ducts was created by lowering the ceiling. You can see the extra thickness at the roof fans. That lower ceiling gives slightly less sense of spaciousness compared to the feel of our Flying Cloud. Of course, the Classic design has a bigger impact on the "feel".
SSquared is offline   Reply With Quote
Old 08-21-2014, 10:25 PM   #208
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Ducted Air
I don't think they lowered the ceiling, I believe they raised ducts above the roofline. The headroom on the 15's is actually technically a little higher because the AC unit is outside.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 08-21-2014, 10:32 PM   #209
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
I'm a little perplexed. Are you sure you camped next to a '15 Classic? I thought that they weren't going into production till October.
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Old 08-21-2014, 10:52 PM   #210
mefly2's Avatar
NO; although it seems that way to you...see the info sheet attachment above in 192 or here:
http://www.airforums.com/forums/atta...3&d=1408133688
We have an extra bump on the front and back of our EB with a raised roofline - in order to give the extra clearance and insulation provided for the ducted A/C.
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
