Old 08-01-2014, 06:48 AM   #169
2014 27' FB International
Macon , Georgia
Originally Posted by switz View Post
A new business opportunity will be figuring out how to clean inside the length of the "hidden" ducting without taking the ceiling down. Over time, duct work does load up with dust and debris and in damp climates, mold. Legionaire's diseae anyone?
Most motorhomes have ducted air and I have never heard of this problem. We had a 27' Coach House motorhome with ducted air in the ceiling for 5 years and never had any dust buildup or mold problems.
Roadtech is offline   Reply With Quote
Old 08-04-2014, 07:30 AM   #170
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Great question on the filter. I might have to look into developing one.... Cut from inexpensive house HVAC filters, and attached internally inside the intake pipe at an angle so as to allow a 20 square inch or more area of flow..... We will see. At the moment I am suffering through a trip staying at motels, albeit one's with character.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 08-05-2014, 10:14 AM   #171
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
A questions for anyone with (2) A/C units Ducted....and one fantastic fan. I have our new 2015 27FB on order and I can change the front skylight (at a custom charge) to a an additional fantastic fan... thoughts? Thinking one skylight is plenty, and 2 fans work better for that occasional quick overnight at Walmat, and boon docking at National Parks, as well as ventlating while in toe. Thank you.
LaBigDogs is offline   Reply With Quote
Old 08-05-2014, 10:21 AM   #172
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Just a 25FB guy here. A skylight in the bedroom would be a waste, to me. We have a fan there and it gets a lot of use. We rarely even open the curtains in the bedroom area.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-05-2014, 10:36 AM   #173
Msmoto's Avatar
2007 25' Safari
Images: 135
Ventilating in tow… yes, two Fantastic fans would do this better than having only one partially open. Maybe replacing the smaller skylight in the hall would work…. or modifying this to allow air flow out of the unit, but rain protected…. lots of possibility if one is an engineer…..
AIR #31871 K4MTL
Old 08-05-2014, 10:12 PM   #174
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I would vote for the fan. Nice to have fresh air and good ventilation. Light I don't think would be a problem. You would also get some light in thru the fan opening.
TinCan
graysailor is offline   Reply With Quote
Old 08-05-2014, 10:54 PM   #175
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by Roadtech View Post
Another question:When will the 2015's with ducted air start shipping?
Ours was delivered to us on July 14 ...
Old 08-06-2014, 10:42 PM   #176
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Images: 8
They started building the 2015 models in May and quite a few dealers have non-Classic models in stock in the various trim lines and lengths.
The standard practice on our 31' Classic and most rear bedroom models is for the rear Fantastic fan to be sacrificed for the rear air conditioner. The rectangular skylight in the bathroom area would not easily convert over to a square fan. The light is really needed and the fan mechanism would block a lot of the light. The bathroom exhaust fan is in that hallway already.
switz is online now   Reply With Quote
Old 08-07-2014, 09:30 PM   #177
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I have a 27FB international with a single AC, so maybe not your target. I really like the hallway skylight. Much brighter. Friends with a Flying Cloud don't have it and it is gloomy in closet/shower/bath area. Not sure, but I guess where your second AC goes is where our second fan is located. Depends where you travel.
kscherzi is offline   Reply With Quote
Old 08-07-2014, 10:51 PM   #178
mefly2's Avatar
Very few 2015 models out there so far ...at least in the NW. YMMV
Old 08-09-2014, 08:34 AM   #179
switz's Avatar
2014 31' Classic
Images: 8
The fan mechanism with a shroud over it does block a lot of light. If we somehow converted the hall skylight in the bathroom area, we would be in a cave with the rear airconditioner.
The following works when the outside air is cooler than the inside. Not as quickly as the airconditioner system(s) but will operate off the standard batteries.
Like our 25FB, a 27FB has two exhaust fans (excluding the cooktop exhaust fan)- one in the shower and one in the toilet/sink area (hope it is explosion proof motor in that gaseous environment). We have a single bathroom exhaust fan. We modified the front Fantastsic fan with their reverseable switch kit so air can be blown in either direction. We turn on the Fantastic fan and bring outside air in (pressurizing if you will) and the cool air comes to the bedroom area and the ceiling heat goes out the exhaust fans.
Since our bed area is in the rear, the FB models would operate in reverse to my description.
Old 08-11-2014, 07:22 AM   #180
LaBigDogs's Avatar
At the factory during production of our unit on the line it's schedule for 1st of Oct to begin. The dealer checked with the factory and they came up with a $1000 charge to do away with the skylight and place a fantastic fan like in the rear in place of. Down south we have an insulated silver reflector that is almost a permanent fixture above the pleated shade in the skylight on our 25fb, and it remains their except for our annual trip to the mountains for a few weeks. We have our bedroom window tinted with 50% and place the same silver reflector between the curtains and the window, to allow temps that are tolerable during 3/4's of the year here deep down in the south.... however with the 2 A/C ducted... this will be a game changer.... so... I have advised them to put the fantastic fan in... but still have time to remove the custom order for the fan. Plan on keeping this unit for a while.... on the 27fb with windows almost most a complete 270° in the bedroom... it's hard to believe that the bath area would be gloomy.... and you use that area just for a few mins a day anyway... (The skylight would allow extreme HEAT inside the unit) 8 hours in the bedroom... weather nice outside...if not in the back ... that is why ducted a/c is so important to me... most of the time spent is the the extreme front of the unit or the extreme rear of the unit.... bath and kitchen are only temporary locations. The roof is full... A/C's, Skylight, fans, exhaust fans, vents, antennas and solar panels...
Old 08-11-2014, 04:16 PM   #181
mefly2's Avatar
Yep !!! A huge difference with the ducted at the ends of the trailer. Spell that C-O-M-F-O-R-T !
Old 08-11-2014, 08:44 PM   #182
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
Congratulations on the new unit. I have a 15 Classic on order due for delivery mid October.
Nelson
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is online now   Reply With Quote
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
