Old 04-28-2014, 06:33 AM   #57
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Is this in conjunction with a roof mounted system?
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 04-29-2014, 03:27 AM   #58
walker's Avatar
1987 34' Excella
Asheboro , North Carolina
Yes. I have 2 Dometic Penguins. Thats what started all of this. I installed the rear one and it was a noisy as the first one. So I took both off and lined them with Dynamat and installed a 3/4" thick mounting foam spacer on bottom of ac. That helped with vibration and compressor noise but air noise inside was still intolerable. So I built the duct work and air boxes. The Coleman that can on this AS new was fine, even in Arizona summer, but these Penguins are not what they should be these days. Bought both new. Factory and Dealer say they are normal. Maybe. But still poor by comparison. If you want the drip pan, you're stuck. Click image for larger version
Name:	ImageUploadedByAirstream Forums1398763644.444757.jpg
walker is offline   Reply With Quote
Old 04-29-2014, 07:14 PM   #59
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Walker
I want to compliment you on your first class design and installation work on your duct work system.
Are you happy now with the noise level and cold air distribution? I assume you can operate either one or both AC units depending on the outside temperature.
Dan
Old 04-30-2014, 03:19 AM   #60
walker's Avatar
1987 34' Excella
Yes, the two units operate independently with the same front to rear duct. The noise level is acceptable. Comparable to other high level RV with ducted ceiling air. We can talk at reasonable level from front coach to bedroom with AC on. Not possible before. At night with only front AC on we have nice air stirring in bed and very quite. The bathroom is another much improved area with a vent placed at entrance.
Old 07-26-2014, 12:50 PM   #61
AirConditioner's Avatar
Ducting approaches??
Anyone else tried this with a single unit yet? If so, what did you use as the ductwork material?
I've attached my approach. I'm considering ducting thru the center light unit and back into the bedroom to reduce noise and drafts.
Any comments appreciated.
AirConditioner is offline   Reply With Quote
Question on 2nd /AC or generator input mefly2 Electrical - Systems, Generators, Batteries & Solar 9 06-18-2012 08:04 AM
so .... afixin to put in a new ac Orlop All Argosy Trailers 2 03-19-2012 05:55 PM
Cutting hole for 75 Argosy AC DearArgosy Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-19-2012 04:32 PM
A new airstream avenue class b van self contained ac generator 190 must see sale eBay Watch Airstreams on eBay 0 03-17-2012 11:10 AM
AC in the AZ bgipeair Furnaces, Heaters, Fireplaces & Air Conditioning 14 03-10-2012 08:37 PM
