Old 06-30-2013, 10:32 AM   #1
matthorr's Avatar
2012 25' FB International
Annapolis , Maryland
Dual zone thermostat?
Does anyone have any experience installing a second temperature probe (in the galley/seating area) with a new Dometic Comfort Control Center II thermostat? It looks like it can control up to 4 zones but I can't find the individual temp sensors for sale.
When I leave the dogs in the trailer, I like to keep them out of the bedroom (less room means less trouble) by closing both privacy curtains. But, since the thermostat is in the bedroom and the a/c vent is in the galley, the temperature control is way off because the curtains block airflow. I'd like to add a second temperature probe in the galley/seating area so it will regulate the temperature properly when the bedroom is sealed off.
matthorr is offline   Reply With Quote
Old 06-30-2013, 11:20 AM   #2
richinny's Avatar
2011 34' Classic
my unit has dual ac's. from the parts list it shows part number 690380-12 SENSOR CABLE 40' DUAL AC ONLY.
if member LEWSTER sees this he might have a lot more info for you. if the number is correct, it will look like a long wire with small sensor on the end.
Ricky
Old 06-30-2013, 11:44 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
YOU RANG?
The remote sensor that you seek is Dometic part # 3106486.008
MSRP is $17.87
Any Authorized Dometic Dealer should be able to order it for you.
Old 06-30-2013, 01:24 PM   #4
richinny's Avatar
2011 34' Classic
lewster, you're starting to scare me! lol.
how does one set up a zone for the extra sensor?
Ricky
Old 06-30-2013, 01:35 PM   #5
lewster's Avatar
THAT is the ultimate question!!!!!!!!!!!!
Actually, the new temperature sensor plugs in to a similar white 2 conductor connector located on the A/C unit. You then have to select which zone it will be (let's assume it is zone 2). To do this, you then have to locate the dip switches on the relay board on the curb side of the upper unit, under the shroud in the little metal compartment help to the frame with 2-5/16" hex head screws.
Remove the cover and you will see a red set of 'dip switches' about mid-board. You have to activate 'zone 2' and nothing else unless it's a heat pump, and then the 'heat pump' switch is also activated, or for a unit with heat strip.....the 'heat strip' switch. Do not activate the furnace of any other settings!
Now close it up and head back to your Comfort Control. Do a re-set of the thermostat and you should now be getting both zone 1 and zone 2. The furnace should only show on zone 1.
Questions??????????????
Old 06-30-2013, 01:44 PM   #6
matthorr's Avatar
Lewster - Thanks! I'll order the part and then the real fun begins... I hope I can run the sensor to the wall above the gaucho TV. If not, I should be able to attach it to the overhead vent for the AC.
Old 06-30-2013, 01:55 PM   #7
richinny's Avatar
2011 34' Classic
lewster, i think i'll save it for you to do in 15 minutes rather than me taking 4 hours :-)
we'll see what happens in the fall.
Ricky
Old 06-30-2013, 02:17 PM   #8
lewster's Avatar
Ideal suggested location for the remote temperature sensor is 54" above floor level away from any sources of heat or cold.
Old 06-30-2013, 05:01 PM   #9
matthorr's Avatar
While I'm up there, should I install a "hard motor start kit" to help prevent popping the circuit breaker / overloading a generator? I have a new model Dometic (Penguin II Heat Pump Model #65185, I think).
Old 06-30-2013, 05:21 PM   #10
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Ha, that's a REAL challenge in these trailers. Maybe in the bathroom
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 06-30-2013, 06:02 PM   #11
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have the same issue with thermostat placement. The thermostat is in the BR. Even with the privacy curtain open, if I set the thermostat to 72 when it's 72 in the BR it'll be 68 in the main area -- cold enough to hang meat! Now if it's 90 degrees outside that equation looks a LOT different.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-30-2013, 07:40 PM   #12
lewster's Avatar
The 'hard start kit' is simply a new start capacitor and PRCT (motor start device). It is the same micro farad specifications as the old one. Unless your old capacitors are not operating to spec. the new kit will not help in your situation.....BUT....... you can install it if it will give you some piece of mind.
