Old 03-23-2014, 11:53 AM   #1
rperrym's Avatar
2017 28' Tommy Bahama
2015 28' Flying Cloud
2014 25' FB Eddie Bauer
Hot Springs Village , Arkansas
Dual Heat Pump Temperature Control
After using both heat pumps in our new FC, I think something must be connected backwards. The front unit, Zone 2, runs until the temperature in the rear, Zone 1 is satisfied. The rear unit, Zone 1, runs until the inside temperature in Zone 2 is satisfied. So, it can get very hot, or cold, in Zone 1 while the heat pump in Zone 1 is still running, trying to control the temperature in the other zone, and vice versa. Is something wired backwards?
I would appreciate any advice. It is on our list for our first factory visit, but if it is something I could correct now, I would do it.
Rick
rperrym is offline   Reply With Quote
Old 03-23-2014, 01:01 PM   #2
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Our Class A had dual units like your Airstream. The main thermostat in that coach was in the front (zone 1), and there was a bedroom temperature sensor (zone 2) that was wired into the main thermostat. When we operated the zone 2 unit from the main thermostat, the zone 2 sensor very accurately told the thermostat when to cycle the zone 2 unit on or off, and the thermostat sensor controlled Zone 1 as needed.
Does your Airstream with 2 HVACs have a remote sensor somewhere on the wall in the front (your zone 2)? If there is only the main thermostat (your zone 1), with no zone 2 sensor, your main thermostat is waiting to be satisfied by a unit 15' away from it.
If you have a main thermostat and a remote sensor, then perhaps the installer swapped the inputs and they could simply be reversed? Does that make Sense? I hope this isn't further confusing your issue............
ShinyPete is offline   Reply With Quote
Old 03-23-2014, 01:19 PM   #3
rperrym's Avatar
I have one wall mounted thermostat, but it shows two different inside temperatures, depending upon which zone you are looking at.
Perhaps there is a second inside temperature sensor, and they are swapped.
Old 03-23-2014, 09:15 PM   #4
richinny's Avatar
2011 34' Classic
my rear sensor was located over the rear television which froze me when the tv was on. i moved it. in my unit the rear is zone 1.
Ricky
Old 03-23-2014, 09:24 PM   #5
1974 Argosy 20
Kooskia , Idaho
Looks like a warrantee issue to me. Airstream should correct it for you.
Water Pump dave_oleary Water Heaters, Filters & Pumps 10 02-18-2014 02:12 AM
pump wouldnt stop running, front valve broke under trailer jasperkins Fresh Water Systems 0 01-24-2014 04:56 PM
Heat Pump glenbrowning Furnaces, Heaters, Fireplaces & Air Conditioning 9 01-04-2012 08:28 AM
No water pump Dan S All Argosy Trailers 2 01-01-2012 05:42 AM
Equalizer vs. Reese dual cam road test dznf0g Hitches, Couplers & Balls 25 08-02-2011 06:30 PM
