Old 05-09-2015, 11:00 PM   #1
2012 23' International
Eureka , Montana
drip
I am camped on the Oregon coast. beautiful weather although high humidity and 50s and 60s temp. which might be relevant to the problem, My overhead electrical heater is dripping water. I am hooked up to electric so to save on propane I have been trying to use the electric overhead heater. I have the thermostat set on auto.
Any advise?
Thanks, Terry
the welder is offline   Reply With Quote
Old 05-10-2015, 07:48 PM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I'm not an expert, since I rarely run the "Heat Pump". But it sounds like you have a clog in the drain line. Hopefully someone else will jump in here, Lewster is the resident expert. It could also be a problem in the drain pan.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 05-10-2015, 09:10 PM   #3
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Have you ever run the HP before? You might read this thread which may be related to your issue. Look for my post about half way down the thread on what I think could be the problem.
http://www.airforums.com/forums/f427/dometic-heat-pump-condensation-leaks-134356.html
Landrum is offline   Reply With Quote
Drip, drip, drip Skamper1 Fresh Water Systems 8 06-12-2010 06:33 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 07:32 AM
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 08:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
