Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 05-26-2008, 08:10 AM   #1
PeteL
Profile:  1965 22' Safari
lewisburg , Pennsylvania
drain tube for ac ??
Considering new A/C install in 1965 Safari 22 as trailer never had AC. My searches have come up empty with process for installing drain tube. Any advice, tips on placement, routing, etc would be appreciated.
PeteL is offline   Reply With Quote
Old 05-26-2008, 08:39 AM   #2
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Put the Carrier on our 1978 Argosy so we wouldn't have to go to the expense of fabricating a new pan. Camping World wanted $800.00 for the pan. I think Inland RV has them now. The Carrier just drains over the side of the Argosy. Since the Argosy is painted this is not a problem. I'm not sure if the same is true for the skin on the AS.
Judy and Bob
At Home in Oklahoma
juel is offline   Reply With Quote
Old 05-26-2008, 09:48 AM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
If you want to use a Dometic unit (what the factory uses on new models) you can get the drain pan from any Airstream dealer.
OR................you can get the Dometic drip kit with 2 little cups, hose, connectors, a second A/C gaesket, etc. and forget about the pan.
Either option is FAR less than $800!!!!!!!!!!!!!
the Dometic stock # is 3107668.016...........
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-26-2008, 09:50 AM   #4
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
It's been reported that wiring and a drain have been installed at the factory for A/C even if it was not installed as an option.
My Globetrotter was partially gutted when I bought it. Never found a drain tube but the wiring was between the two roof vents.
The Coleman on the GT drains down the street-side skin. Haven't had a problem in 8 years.
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 05-26-2008, 10:11 AM   #5
Whizzo
Whizzo's Avatar
Profile:  2008 22' Safari
Helotes , Texas
Images: 12
The A/C drain routing still needs help, even on new units. Thanks for the tip on the kit, because right now my streetside tire looks like a passing pooch is wetting it down.
2008 Safari Sport 22
2003 Ford Explorer NBX, 4.6L, 3.73
Hensley Arrow Hitch, McKesh Mirrors
Whizzo is offline   Reply With Quote
Old 05-26-2008, 10:12 AM   #6
toastie
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
Livingston County , Michigan
Check this tread out... AC condensation drain tube this is how I ran my drip tube.
toastie is offline   Reply With Quote
Old 05-26-2008, 10:18 AM   #7
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
Is that how you got your forum name?
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 05-26-2008, 10:20 AM   #8
Whizzo
Whizzo's Avatar
Helotes , Texas
Images: 12
Pretty close. Did you ever see that t-shirt of a little cowboy titled "Whiz Kid?"
Old 05-26-2008, 10:22 AM   #9
cameront120
I've never seen that. Now I'm curious.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 05-26-2008, 10:26 AM   #10
Whizzo
Whizzo's Avatar
Helotes , Texas
Images: 12
Can't find it on the Web. Dates from 25 years ago. I'll send you a PM if I find it, rather than take this thread too far OT.
How do I clean my AC drain tube? tyndalelady Furnaces, Heaters, Fireplaces & Air Conditioning 37 09-15-2008 08:03 PM
AC condensation drain tube IndyAnne 1959-69 Tradewind 10 04-10-2008 04:05 PM
Help ! In need of a burner tube. C Johnson Stoves, Ovens & Microwaves 10 10-25-2006 11:32 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 05:09 PM
awning roller tube bob.rita Parts Archive 4 07-28-2003 06:37 AM
test
