Old 09-06-2010, 07:18 PM   #1
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Dometic penguin "pan base" ?????
Just removed the AC today trying to find a leak.
The AC unit is a Dometic Penguin model # 600315.321 I am guessing mid 1990's, because thats when the trailer was redone.
The plastic "pan base???" that collects all the condensation, and is below the entire unit is cracked in several places.
Is this a common problem??
Any idea where I can purchase a new one?
What is the correct name for this part?
Any info is greatly appreciated
Thanks Larry B
larry b is offline   Reply With Quote
Old 09-06-2010, 07:29 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
We have the Dometic units. Someone screwed-up the installation. The Airstream part number we have for the "A/C Pan for roof air" is 961270. Your RV guy will prolly have to order through AS.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-06-2010, 07:51 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
You can avoid using a plastic base pan entirely by installing a Dometic auxiliary drain kit, part # 3107688.016.
These kits are used on just about every Duotherm installation that requires the use of an internal drain hose like Airstreams and most other quality RVs have.
The kit consists of 2 catch cups that are attached directly beneath the drains. These cups have molded-in nipples which connect to the supplied tubing. The water drains from the tubing via a 'T' fitting that connects to the interior drain hose. An extra gasket is also included to raise the unit slightly to provide clearance for the drain cups.
You might check it out!
They DO work well!!
Old 09-06-2010, 09:12 PM   #4
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
larry,
you can order the drain pan from AS they cost about 60 bux.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 09-07-2010, 06:11 PM   #5
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Thanks all for the responses, I called AS today and they told me I had to purchase from a AS dealer. Paid 70 bux plus shipping for a new drain pan. I was told I should have it in 3-5 days. Hopefully It will arrive before the weekend so I can put her back together. Keeping my fingers crossed that this will solve my leak over the kitchen sink. Its really the only place left!
Thanks again,
Larry B
Old 09-07-2010, 06:21 PM   #6
Mike Leary's Avatar
Images: 11
Remember to use a small air compressor on the lower drain every few seasons, especially if pine/fir needles are in your area.
Old 09-08-2010, 03:49 AM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Thanks again,
Larry B
He said confidently until the next good rain storm....
Dometic Duo-Therm "Cool Cat" heat pump/AC unit?? PA BAMBI II Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-19-2010 08:52 PM
Is Dometic EOL'in their Compact "Freedom" line? ronstory Refrigerators 3 08-31-2008 08:27 PM
air cond "pan" George Furnaces, Heaters, Fireplaces & Air Conditioning 7 05-12-2003 01:48 PM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
