Old 08-13-2011, 07:10 AM   #21
Rockvale , Tennessee
Terry,
I have to agree with you. Not sure what was going on in my mind. You bring up an excellent point. The important part is if a capacitor is added, significant testing needs to be done to insure correct performance. I doubt most have the equipment time or knowledge to do it correctly. It can be a can of worms.
A small generator may trouble starting heavy load especially if that is the only load. A fan "on", may actually help add inertia to the system and help with the starting. While some may have problems and others not, really depends on many factors, including various loads and operating conditions.
Most modern electronics use SMP (switch mode power) supplies. Many are universal voltage input, and work by rectifying the AC to DC to charge a large capacitor, then use a switching regulator circuit to convert to lower voltage. The end result is they are tolerant to power noise and ride out dips in voltage. Older electronics with linear supplies may have problems with less than ideal power quality.
Dave
KitCarlson is offline   Reply With Quote
1967, 1967 caravel, air conditioning, caravel
'67 Caravel Door lock Question vonzellen Doors & Locks 14 11-29-2011 02:26 PM
'67 Caravel Airconditioner recommendation vonzellen 1966-68 Caravel 3 11-01-2011 12:54 PM
67 Caravel and Armstrong Air not working vonzellen Furnaces, Heaters, Fireplaces & Air Conditioning 8 03-02-2011 02:24 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 06:07 PM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 08:25 AM
