Old 09-30-2005, 01:19 PM   #1
Dometic penguin logic board
has anyone on this forum replaced the logic board as the culprit for compressor failure, My compressor will not start, so I used an amp meter to see if it was getting AC to the compressor. I used it in line after the logic board terminal, could the relay be stuck or burned? a 200 part is better than replacing a 700 unit.
thanks for any info on this.
0557 is offline   Reply With Quote
Old 09-30-2005, 04:36 PM   #2
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Don't know if this is specific to your issue, but here's a thread on Dometic Logic board replacements.
http://www.airforums.com/forum...hlight=tin+hut
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 09-30-2005, 05:59 PM   #3
Cracker's Avatar
Pittsfield , Maine
Penguin A/C
I just returned from a trip to the Mothership in Jackson Center to resolve my A/C problem. Airstream installed a new logic board - but the A/C compressor would still not kick in. The end result was that we replaced the entire A/C unit - as it appeared that the problem was "loss of coolant." Jackson Center is not equipped to "break in" to the system and there are no "ports" available for testing the coolant pressure. Since this is a "heat pump" unit, the net replacement cost was over $1500, plus labor. The thermostat also had to be replaced since the new units have 5 buttons vs 4 and there is no way to modify the wiring. The only "salvageable" items were the mounting pan and the interior vent assembly. This was a hard pill to swallow for a unit barely five years old! I hope that you have better luck!
Cracker
Cracker is offline   Reply With Quote
Old 10-10-2005, 09:47 AM   #4
Nye Thatcher's Avatar
I would first check the capacitor. The capacitor gives the boost to start the compressor. This is simple to check and not expensive (a couple of dollars).
If this is it, check with your local A/C supplier and don't hesitate to put in a universal capacitor that he might recommend (been there, done that).
Hope this will help. Good luck.
Nye
Nye Thatcher is offline   Reply With Quote
1977 Dometic refridgerator overlander Refrigerators 30 03-14-2015 12:08 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 11:57 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
