Old 06-23-2014, 03:51 PM   #1
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Dometic Penguin 2 install tech question.
Hi all,
I have installed a new Penguin 2, wired it all, installed the ccc2 thermostat and nothing happens. The thermostat is blank, no codes or anything.
I have power to the unit, 110v and 12 volt, and I can trace 12v down to the ccc2 with a test light on the rj11 connector.
Its a Dometic penguin 2 low profile model 641816.
Does anybody have any thoughts? I missed Dometics support hrs today.
Mark
2005 Ford Excursion V-10
Reese Trunnion Bar with dual cam sway control
Prodigy P3 brake control
seldencove is offline   Reply With Quote
Old 06-23-2014, 04:09 PM   #2
r carl's Avatar
Lin , Ne
I would test the thermostat to see if its dead if your sure its all wired correctly.
Old 06-23-2014, 05:16 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
What did you use for the comm cable from the A/C unit to the CCC-II? Standard phone cable does not work. The ends have to show color continuity when the tabs on the jacks are in the same orientation and are facing each other.
Lew Farber
RVIA/RVDA Nationally certified Master Tech
Master Tech RV Systems, Inc.
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-23-2014, 06:58 PM   #4
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Lewster,
I used cat5 cable, crimped my own ends, payed attention to make sure same color wires were orientated the same way on each connector. Ended up redoing connectors a few times because I thought that might be the problem. I bought a 4 conductor phone cable today and tried that too, nothing.
When you say the connectors are facing each other, that makes me wonder.
With the tabs facing up, I started left to right with my color combination.
Old 06-23-2014, 07:29 PM   #5
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Went out and checked my com wire, they were backwards. redid connectors so with both tabs up, facing each other, color combination matches.
Nothing changed. ccc2 blank screen.
Perhaps I fried it with wires crossed?
Thanks for the help.
Mark
Old 06-23-2014, 07:43 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
To the greatest extent, as long as both ends of the cable are identical, backwards wont matter and certainly will not induce a short.
Old 06-23-2014, 09:46 PM   #7
lewster's Avatar
Check the 3 amp fuse on the relay board. Also, try the other phone jack on the board for your comm cable.
Old 06-24-2014, 06:04 AM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
Be doubly sure you cable is wired straight through. The two connectors should be wired the same and not be mirror images of each other. So if you have, on one end, from left to right, white/blue - blue - orange/blue - orange then you should have, from left to right, white/blue - blue - orange/blue - orange on the other end. If you hold them up so the connectors face each other the wires should not match, they should reverse.
This is the opposite of what is used for telephone connections.
Old 06-25-2014, 04:40 AM   #9
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
I checked the 3 amp fuse last night and couldn't find one. Took the shroud off checked the circuit board area.
I have 12v coming into the board. Checked with light probe.
I will work on the com wires tonight to sort that out.Click image for larger version
Name:	ImageUploadedByAirstream Forums1403692801.480709.jpg
I have ordered a new ccc2 just to rule that out.
Thanks everybody for helping.
Mark
Old 06-25-2014, 05:11 PM   #10
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Update:
It was a bad ccc2, wired a new com cable the way Jammer suggested, plugged in the ccc2 and was still dead. Ups brought the new one I ordered, plugged that one in and its working great!
Thank you all for the help, it was really stumping me.
Mark.
Penguin install cwf Furnaces, Heaters, Fireplaces & Air Conditioning 30 07-21-2013 04:50 PM
Tech Support Wouldn't/Couldn't Answer My Electrical Question murreywalker Batteries, Univolts, Converters & Inverters 24 06-27-2012 12:59 PM
Dometic Penguin A/C Control Panel Board Saigon Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-05-2004 10:55 AM
Dometic Penguin A/C Main Cycle Board Saigon Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-03-2004 02:20 AM
Dometic Penguin for '66 Safari? markh8624 Furnaces, Heaters, Fireplaces & Air Conditioning 21 02-24-2004 05:30 PM
