Furnace repair
Hey Chris, It is necessary to include all the info ya can about a question. It is very difficult to trouble check anything from 1000 miles. I don't have a AS motor home, but I know electrical. Does this unit have 2 furnaces?? Also 2 t-stats?? Does the other LPG appliances in the RV work?? If this unit has just a single furnace, the ducting from the furnace must be restricted. If there are 2 furnaces and one will not lite, the LPG line must be restricted or blocked. The only goood test for the LPG supply is to remove the line from the furnace, and sniff for gas. A helper is good to have so as to turn off the main supply after smelling for gas. A furnace needs only a few items to operate, as at least 11 volts, fresh air and LPG fuel. If ya give me more, I can give ya more....... Frank
Visit Idaho The people are great
