Old 07-25-2014, 06:42 PM   #29
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
.... I had to check the AC, one more time. It still works.
The few seconds for the fan to start blowing and the 2 to 3 minutes for the compressor to start up afterwards. Just remember the delay of the compressor starting up 2 to 3 minutes AFTER the fan is blowing. If you do not know about the delay, you could have a perfectly operating system and just shutting it down too soon.
Ray Eklund is offline   Reply With Quote
Old 07-25-2014, 09:10 PM   #30
lewster's Avatar
Naples, FL , Hood River, OR
Old 07-25-2014, 11:30 PM   #31
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Thanks, Ray, for posting the details and photos, which I will save for future reference!
SilverGate is offline   Reply With Quote
Old 10-03-2014, 08:29 AM   #32
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Why Penguin Air Conditioners dis continued
In my search for an inexpensive, as possible, A/C I have discovered that many of the Penguin models are discontinued. Can it be from the rash of problems noted here? There are replacement models....BUT, I see where you have to be knowledgable when buying. I see lots of "good" prices appearing from wholesale sellers and salvage folks. I am going back the another Mach 8. Wish the Carrier low profile was still being made....I have one which has been perfect for the past four years.
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Dometic Duo Therm Penguin 13500 problems NJ2Cali Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-30-2013 01:41 PM
Dometic Duo Therm Penguin gloran Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-20-2007 11:06 AM
Need Dometic Duo Therm Penguin air distribution box gloran Land Yacht/Legacy Motorhomes 1 01-20-2007 11:00 AM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
