Old 09-26-2015, 03:25 PM   #15
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Originally Posted by SuzyHomemakr View Post
Hey Don-
Can you give us a spec on those A/C vents? I've tried messing around with my Brisk II vents, but all I was able to accomplish was icing up the blasted thing!
If I had it to do over again, I think that I would have bought two portable A/Cs, and covered up the hole in the roof!
You have to make these up as you go along. The first thing is to seal off the front vent in the Air Box along the sides just forward of the side vents so no air goes to the front. Then I lined the Air box with the Reflective insulation and sealed off the bottom vent as well. It leaks air and serves no real purpose. Now you have the 2 side opening and the the rear opening for the cold air flow. I cut pieces of cardboard to fashion a vent to fit the contour of the sides and ceiling using masking tape. From this I made a pattern of the pieces and started cutting my thin plywood to make the the side ducts that now direct the cold air to the front. Once I had this in place I ordered by louvered vents and again working with cardboard to make a pattern for the finished plywood piece to hold the vents in place. Look at the picture and you should able to see what needs to be done. Good luck
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Dometic Brisk II Air Conditioner adonh Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-25-2013 10:59 AM
Duotherm Brisk Air texascanuk Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-07-2011 08:36 PM
Brisk Air New Style Shroud seawaatty Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-25-2010 12:27 PM
Duo Therm Brisk Air JAG Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2002 08:29 PM
