Old 06-25-2013, 09:44 AM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Dometic Brisk II Air Conditioner
Dometic has introduced the new Dometic Brisk II Air Conditioner as covered in the following online announcement. Any thoughts on this one.
Dometic Introduces the Brisk II Air Conditioner for RVs
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 06-25-2013, 10:12 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Don,
I posted this on a thread titled "Dometic Brick Air II'. You might find it of interest. Plus, this unit has been out for over 6 months.
Olie,
Just a few observations that I have recently become aware of.
I had a client with a 2006 Country Coach diesel pusher that had 2 older model Penguins on the roof....both 13.5K heat pumps. One went out (lost refrigerant) and the new Penguin II was not compatible with his existing Comfort Control I thermostat system. He opted to buy 2 new heat pumps (15K) and upgrade to the new Comfort Control II system for better service and parts availability in the future.
After about a month, he was on the road to a summer vacation in Maine and called me from a large RC service center. He said that his new Penguin II units were extremely loud and were vibrating excessively. He called Dometic tech support and was told that they are having problems with the new compressors needed to properly handle and compress the new R-410A refrigerant that is required now for air conditioners.
Part of the problem is that R-410A is harder to compress than R-22 and requires a more robust compressor spinning at faster RPMs. This makes them prone to excessive vibration and noise.
The Dometic folks offered to replace the both Penguin II units with the Brisk Air II and pay for the change-out labor. The client accepted. When he called me, the tech was having problems getting his new units mated to his CCC-II thermostat, so I talked him thru the process of dip switches and thermostat re-sets.
The client called me the next day and stated that he was very happy with the new unit's cooling capacity (both 15K units) and especially the much lower interior noise level of the Brisk Air II units. He also said that while he was NOT happy with the elevated look of the new units, it was a trade-off that he was willing to make for the reduced interior noise levels.
I have to say that I install about an even amount of both types of units and I have heard complaints about both. I especially took note of this client's reactions as he is in the analytical field and has excellent observation skills.
Something to consider.............
Old 06-25-2013, 10:32 AM   #3
1981 31' Excella II
New Market , Alabama
I have a Briskair that is about a year old and the fan makes as much noise as anything. I can tell when the compressor is running but the noise level does not seem any worse than the old Coleman Mach III it replaced.
Perry
Old 06-25-2013, 10:40 AM   #4
Olie's Avatar
2004 30' Classic
Beaumont , Texas
Adonh,
This is the one I was asking about in my post yesterday. It has the advantages of being smaller, lighter at 74#, greater cfm and maybe more sound dampening than the Penguin II. The disadvantage to some is the extra height compared to the Penguin. I think its worth considering when upgrading to 15000btu.
Lewster, thanks for your input.
Olie is offline   Reply With Quote
Old 06-25-2013, 10:59 AM   #5
adonh's Avatar
1976 31' Sovereign
Thanks, the quest for the coldest RV AC continues.
Don Hardman
1976 31' Sovereign
