Old 06-17-2019, 06:29 PM   #1
1972 25' Tradewind
Albany , Georgia
Images: 8
Dometic Blizzard with a Heat strip?
Good evening all.
I just put a 15000 Domentic Blizzard on our 25 ft tradewind. My goal was to install this with the heat strip controlled by the CCCII thermostat. The thought being, turn on the heat strip when the temp goes below freezing to just keep the inside about freezing (currently done with a space heater).
I called and talked to someone before ordering (did not write down a name) and was told this was good with the part numbers I was ordering, but when I did the AC install, there is no where to plug in the heat strip.
Called the vender today and they called Dometic... this time I was told the heat strip will not work with a Blizzard. part numbers I ordered are:
H541816W *BLIZZARD NXT AC PW W/CCC2
3314850.000 NON DUCTED ADB KIT BRISK
3314082.011 THERMOSTAT, PKGD CCC2-WHI
3314998.000 *HEATSTRIP BRSK 2
Does anyone know if it is possible to get a heat strip working with a 15000 blizzard?
Will
meadowlm is offline   Reply With Quote
Old 06-18-2019, 12:09 AM   #2
2007 27' International CCD FB
San Diego , California
When I originally ordered my Blizzard through PPL Motorhome, I was told I could and opted for a heat strip too. Fortunately, I doubled checked the configuration and part numbers through Dometic themselves before anything shipped and was told it was incompatible.
After following up, I do not believe you can opt for a heat strip with the Blizzard.
It's for the better IMO, as the A/C fan is noisy. Hot air being circulated from the top is not ideal either.
I opted for a couple of these from Amazon. Cheap and work great. They have a low and high setting with thermostat, and are unobtrusive plugged directly into the outlets.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 06-18-2019, 05:01 AM   #3
1972 25' Tradewind
Albany , Georgia
Images: 8
Thank you for the reply.
It is very dissapointing call and be told one thing, order the parts, and then be told, that is not possible.
It does seem like with the possiblilty of mulpiple zones of the CCCII and the two wires to control a furnace....
Oh well
Heat Pump vs Heat Strip Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 5 03-11-2018 11:07 PM
Dometic Blizzard AC Unit AnnArborBob General Repair Forum 6 07-20-2017 11:32 PM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
