Old 07-04-2006, 02:34 PM   #1
Holland's Avatar
1971 27' Overlander
1963 22' Safari
Venlo
Dometic Airco dual voltage ?
Hello to all,
As we have no manual, we want to ask our question here:
On our AS we have a 1 or 2 year old dometic dual therme airconditioner,
that was installed in the USA by it's former owner.
The AS now is in Holland and we have 220 V over here, question is,
will there be a switch somewhere in the unit, to flick it from 110V to 220V?
We have our trailer in the storage, far from home, so we won't be able to
just check it that easily...
Hope someone of you knows the answer.
Thanks a lot for your answers upfront,
Pieter and Kai
Holland is offline   Reply With Quote
Old 07-04-2006, 03:37 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hi Pieter and Kai,
Welcome to Airstreaming! I don't think the Dometic's are dual voltage. Also you will need to do something with your Univolt power converter. Another European member on the board has had issues with his. They are also set up for 120v 60hz. Putting 220v 50hz to them has a tendency to drastically shorten their life span. Check out the Dometic site for Holland. It has a list of all the neat stuff they make for EU that we can't get in the states. I would check around with you local RV places to see what they have available for you to convert with. I know there are several other Airstreams in your part of the world and I am sure they had to convert the electrics on them. One that comes to mind is at Route 64 The lady that imported it is Carla Kneepkins and is a member of this forum.
Good Luck and let us know how you make out.
Aaron
WBCCI #XXXX AIR #2495
Old 07-04-2006, 06:32 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Exclamation No, No, NO!!!!!!
Originally Posted by Holland
Hello to all,
Pieter and Kai
Pieter and Kai,
You will destroy the motor and compressor in your Dometic and possibly burn them, along with the Univolt if you run them on 240/50 current. There is no fix that I know of that will allow you to use them as they are on the European standard. That also goes for anything electrical in your trailer, Electric element on the refrigerator, furnace blower motor, etc.
Dometic is a European company and they make 240/50 units but you will need a totally new one and you can probably convert the fridge element as well. You will need to change the Univolt to a WFCO or Iota converter that is made for 240/50, and a new blower motor for the furnace.
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Alternator/ Voltage reg LKappenman Mechanics Corner - Engines, Transmission & More... 7 10-24-2002 10:24 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
