Old 05-27-2013, 04:43 PM   #1
Winemaker
rgwatkin's Avatar
2012 28' Flying Cloud
Avila Beach , California
Dometic air conditioner tripping breaker
I have a 2012 Flying Cloud that is tripping the 20A breaker after running the air conditioner for about 10 min. Can reset and it runs for another 10 min. Outside temp 88deg. Is a new problem Asquith I have run successfully in the past. Any thoughts?
Rich
rgwatkin is offline   Reply With Quote
Old 05-27-2013, 04:58 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
What's the power supply? Are you plugged into a 30A outlet or running it from a regular 15A household outlet, etc...
Also, did you measure the voltage at the outlet or on an outlet in the trailer when the AC is running?
David
Old 05-27-2013, 05:20 PM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Are you using an extension cord other than the 30a shore power cord?
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 05-27-2013, 06:34 PM   #4
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
If you have checked the previous things mentioned and you are still having a problem, the unit may just need a rest overnight in order to reset it self. I only say this because that is what solved the problem when mine was doing the same thing. Of course, it only did this in Florida when the temp was 90 and the rh was 99%. I think it gibbled it self due to the humidity and we didn't have the Airstream closed up enough. That is, one or two windows were open a crack. How's that for a technical solution? Perfect. Do nothing but wait. Worked for me.
Jim Flower is offline   Reply With Quote
Old 05-27-2013, 06:53 PM   #5
1988 32' Excella
Robbinsville , New Jersey
You mean it might have froze up?
Another question, is there anything else on the circuit with the AC?
Old 05-27-2013, 07:04 PM   #6
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Maybe, I just don't know. Same with the AC breaker. It hasn't been enough of a problem to mess around with it.
Old 05-27-2013, 08:01 PM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Measure the voltage on one of the outlets without the air conditioner turned on. It should be 110 to 120 VAC. Turn the air conditioner on and the voltage should not drop below 105. The air conditioner will pull excessive current if the voltage drops down to 100 VAC and that will pop the breaker. Is the breaker that is popping in the trailer or in the power supply? If the voltage is acceptable, it could be a defective breaker.
Old 05-27-2013, 08:41 PM   #8
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Rich, I would suggest you add a surge protector to you power cord, buy a good one. Low voltage, lightning strikes, reversed polarity, and other electrical issues can cost you a lot of money in damaged equipment. The best ones have a digital read out with error codes and a time delay before reset to let the AC equalize before restart. It lets you know if you have bad power before you plug in the trailer, mine stays online 24/7 at home and on the road.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 05-28-2013, 12:08 AM   #9
richinny's Avatar
2011 34' Classic
is the water heater off or on propane?
the converter will draw more if the batteries are low.
compressors draw more power when hot.
a dirty plug or outlet can increase the amperage needed.
Ricky
Old 05-28-2013, 01:03 AM   #10
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
Since its a 2012, I'll assume its under warrentee. If so, my advice is don't mess with it, go right to a dealer and get if fixed, before you do something to void the warrentee. YMMV
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
