Old 07-27-2016, 07:16 PM   #1
2015 19' Flying Cloud
Dallas , Texas
Dometic Air Conditioner
Currently on the road and stopped at a KOA for the night. I have a 2015 19 ft Bambi. I tried to turn on the air conditioner and code E4 is showing/blinking on the thermostat and I can not get any mode to come on. Any suggestions? It was working yesterday(the Air conditioner). I'm currently plugged in to a 30 amp. Thanks.
Mark
Lets go is offline   Reply With Quote
Old 07-27-2016, 07:40 PM   #2
Lets travel's Avatar
2014 30' Classic
Fayetteville , North Carolina
E4 means the defrost sensor is the problem, this is located up in the unit on the roof.
Lets travel is offline   Reply With Quote
Old 07-27-2016, 09:05 PM   #3
Dallas , Texas
Code E4 Dometic
Thanks. So if it is on the roof, what needs to be done up there ? Reset it or can it be be reset at the thermostat?
Mark
Old 07-27-2016, 09:22 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Actually, the defrost sensor is located IN the evaporator coils. It's also called a freeze sensor and is a metal cylinder about the thickness of a lead pencil, perhaps 2" long with IIRC a thin, white duplex wire coming from it . It is pressure fit between the fins at the front of the evaporator.
As they rarely go bad, I would suspect that either the plastic snap-in connector has come loose or it has lost contact with the upper relay control board.
You will have to remove the upper shroud along with the styrofoam cover over the evaporator section and then the plastic eval. housing to access the freeze sensor.
If you have non-ducted air, you might also be able to access it by dropping the air distribution box that's located on your ceiling.
Old 07-27-2016, 10:32 PM   #5
Dallas , Texas
Thanks for the details. I will try to check it out.
Mark
Old 07-28-2016, 01:36 PM   #6
2014 30' Classic
Thanks Lewster, I was hoping you would jump in.
Dometic Penguin Air Conditioner Starting Capacitor Cracker Furnaces, Heaters, Fireplaces & Air Conditioning 16 10-15-2015 07:33 AM
Dometic Brisk II Air Conditioner adonh Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-25-2013 10:59 AM
Penguin Dometic air conditioner shroud and pan A W Warn General Repair Forum 12 06-09-2013 06:19 AM
Dometic air conditioner tripping breaker rgwatkin Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-28-2013 01:03 AM
I need a good source for dometic Air Conditioner parts 0557 Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-18-2004 04:31 PM
