Old 05-06-2014, 02:39 PM   #1
2009 27' FB Flying Cloud
Colorado Springs , Colorado
Dometic A/C mounting bolts
Have been experiencing leaks from rain entering my 2009FC 27FB for a few years now. Snugging up the mounting bolts helped up until a month ago. Decided to replace compression gasket. Discovered only three mounting bolts are used to secure A/C and compress gasket even though there are five mounting bolt positions and five bolts that come with the Penquin unit. AS service dept. says three are all they use--along with copious RTV--according to installation agreement with Dometic. Am I the only three bolt guy out there? What do they do with the extra bolts? I can see how leaving out two bolts could shave 90 seconds from the installation process. Dometic only wants $19 for the bolts plus $15 shipping. How can a square gasket be properly compressed with three bolts?
Doug2009FC is offline   Reply With Quote
Old 05-06-2014, 03:32 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I just installed a Dometic last summer, and the installation kit only had three bolts in it. I too had my doubts about the 3 bolt set-up, but so far I have had no leaks, and every time I return from a trip, the AC is still on top the trailer.
good luck!
Old 05-06-2014, 03:37 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
If you mean "RTV Silicone," please don't use it on aluminum. It will cause leaks and it's a biscuit to remove once you do put it on. You want a urethane sealant - search these forums for some excellent advice on the urethanes.
Old 05-07-2014, 02:56 PM   #4
1963 19' Globetrotter
Moline , Illinois
The latest issue of Trailer Life has a great tech article on just this subject. I think you would find it quite helpful.
63air is offline   Reply With Quote
brake plate mounting bolts Safari64 Brakes & Brake Controllers 4 09-06-2012 12:36 PM
Axle mounting bolts-best lube to free up? rogerdodger Axles 21 06-01-2012 09:47 AM
Door hinge bolts/access hole ViewRVs Airstream Motorhome Forums 9 04-29-2003 08:44 AM
lug bolts Chas Axles 3 02-18-2003 09:55 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
