Old 01-19-2015, 02:47 PM   #15
Ottawa , ON
Best posts I have seen so far on Armstrong upgrade
Here is a link to THE most impressive overhaul and upgrade that I have seen regarding the Armstrong.
Jim Pratt's '69 Ambassador got upgraded to more power output, and Jim even added a reversing valve that turned his Armstrong into a heat pump as well!
He didn't seem to have any problem finding the parts to do it, either.
Old 01-19-2015, 07:27 PM   #16
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Thanks, Aage.
It is.
Old 01-19-2015, 09:02 PM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
That link is very impressive. It is the first link I bookmarked after I joined the forum.
Before I started reading about the Armstrong units and others on this forum I had decided to scrap the old dinosaur in favor of a new unit for the sake of reliability.
I owe a debt of gratitude to the posters who have praised these old units, they kept me from making a big mistake, so I try to pay it forward every time I get the chance.
So far that cooler has run A LOT for two long hard summers without any issue. (Other than the screw I mentioned above)
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 01-19-2015, 09:16 PM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I had to pass on one of the factory custom shrouds for one from a Streamline. Still irritated at that.
Old 01-21-2015, 05:35 AM   #19
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
What about changing a compressor? Is that a D.I.Y. project?
terrencecolp is offline   Reply With Quote
Old 01-21-2015, 06:05 AM   #20
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Replacing a compressor is a do it yourself job if you have all the tools needed to change an a/c compressor and know how to change one. A/c gauges, vacuum pump, freon reclamation unit, acetylene torch and silver solder, compressed nitrogen, and a can of freon... You have to purge the system with the nitrogen while soldering in the new compressor, you have to vacuum all of the air out of the system before recharge, you need to know how much of a recharge is needed...
It's not just a yank it out and slap in a new one kind of operation. You need to know what you're doing...
-Red, it's what I do...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-23-2015, 09:44 AM   #21
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I will be replacing my own when the time comes. I have about decided to use flare fittings and set up with R134 ports. I have a vac pump.
(I will fill with R22)
Old 01-23-2015, 01:47 PM   #22
Panama Red's Avatar
Obrien , Florida
Go ahead and use standard A/C valves. They'll be compatible with the gauges you need to hook up the canister of R-22. As far as flare fittings, I like the idea, but you'll still have to torch some copper to flare to the compressor. If you're torching anyways... Might as well make the connection.
-Red, giving away all his secrets...
1987 P30 R12 Freon Capacity 8rmesse Classic Motorhomes 21 05-15-2013 06:26 AM
any ideas??? Dometic to freon conversion? bookman Refrigerators 8 09-20-2008 01:13 PM
AC needs freon charge? 1977 excella gunny2007 Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-13-2007 06:39 AM
Electric/freon type RV Refrigerator adonh Refrigerators 2 05-03-2007 03:49 PM
Armstrong freon charge Gino Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-02-2004 12:18 PM
