Old 05-26-2007, 06:35 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Does burning propane =water?
If we use the refrig and furnace using propare, will water be generated and if so, is there drain valves in the Argosys? Or, is it vaporized in the air?
Dan
Dan S is offline   Reply With Quote
Old 05-26-2007, 07:00 PM   #2
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
I don't believe and water is produced at all...except possible for condensation on the ammonia coils in the refer. Propane does not produce an extrodinary amount of gasses such as carnon monoxide (not sure but I think starved of O it might, but not when completely burned). Darn, that is all I can conjor up from my memory...and anything I say may be wrong
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 05-26-2007, 07:44 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
The list of by-products from the combustion of propane does not include water. Carbon dioxide and carbon monoxide are the major off-gasses. neither of these you want in an enclosed area. Propane does require a substantial amout of Oxygen for combustion.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 05-26-2007, 08:05 PM   #4
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
Yes. The burning of gas will produce water vapor. The furnace and refer vent out side. The stove will not be a problem because of the power vent to pull CO out. If you have a catalitic heater you may see some condensate.
"Humans get a lot done,not because we're smart, but because we have thumbs so we can make coffee." Flash Rosenburg
"Decaffinated coffee is the devil's blend."
GO Bob is offline   Reply With Quote
Old 05-26-2007, 08:40 PM   #5
2002 19' Bambi
Lafayette , California
GO Bob is correct. Burning propane produces water.
Propane is C3H8, that is 3 atoms of carbon and 8 of hydrogen. Complete combustion of propane means that those atoms combine with oxygen to produce CO2 (carbon dioxide) and H2O (water). Carbon monoxide (CO) is produced if combustion is incomplete (not enough oxygen is available). Carbon monoxide is very poisonous. With complete combustion, the water is given off as a gas (water vapor) as is, of course, the carbon dioxide. The water vapor will condense into liquid water if it cools enough.
Tim A. is offline   Reply With Quote
Old 05-26-2007, 09:15 PM   #6
Dan S's Avatar
1975 Argosy 26
I asked the question as I am wondering if I should expect to see water dripping below any of the propane appliances while in use.
Dan
Old 05-26-2007, 11:19 PM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
No.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-27-2007, 06:21 AM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Dan
I've never seen water coming from LP appliances as a result of the propane combustion process. You will get some moisture in the fridge compartment from either condensation on the cooling coils or from the interior condensate drain that exits at the rear or the fridge.
Old 05-27-2007, 06:54 AM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
"Propane appliances" is pretty general. What are you seeing?
5 meter Langford Nahanni
Old 05-27-2007, 08:04 AM   #10
tpi
Trabuco Canyon , California
I see a little condensate dripping from my Attwood water heater. It happens when I first start it in cool weather and when the water inside is cold (40 degrees F).
I confirmed it is from the burner tube, not the relief valve.
tpi is offline   Reply With Quote
Old 05-27-2007, 11:21 AM   #11
Excella CM's Avatar
Venice , California
Just physics
That's normal. The exhaust gas is full of water vapor. If it hits a cold surface or atmosphere it will condense. You see this on auto tailpipes in the morning when they arae first started. As the system warms up the vapor quits condensing and becomes invisible. Just physics.
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
