The Armstrongs were built to commercial specs and are tough units. The one on my '77 Excella 500 was not blowing cold air so I used a wire jumper on the thermostat (actually under the inside thermostat cover). The compressor still did not energize. I took the cover off the AC and measured the voltage into the transformer on the streetside of the unit and then the low voltage side. 125 v. going in and 14 or so going out. It should have been 24 volts best I can remember. I then measured voltage at the thermostat and found that it was only 9 volts. I went to an electrical supply house and found a transformer that met the specs in the manual. It was a little larger than the one it replaced but as soon as it was wired up and the thermostat turned to a lower setting, the compressor energized. Good cold air.
Freon was just a little low so I had a friend with proper equipment top it off. Maybe all you will need is freon but check your service manual if you have one to find the jumper locations at the thermostat for a quick check. If not, PM me and I will check the manual to give you the right spot.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
