Old 03-06-2004, 04:27 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Question Do you suppose this part is still available?
Took my furnace out today...needs to be cleaned and adjusted. last time I used it, it ran fine. only problem was that it was "sooting" quite a bit on the outside. manual says to increase combustion air, but the adjustment screw is already turned all the way up.
Anyway, when I took it out, I found that the vent cap adapter is badly corroded. the screw holes sort of disintegrated as I was trying to remove the screws that attach it to the flange around the furnace's exhaust pipe. (that's got some rust on it, too, but it looks salvageable). It looks like the vent cap may be the sort of thing that hasn't changed much over the years, but I don't know for sure. anyone know if these are replaceable?
furnace is a suburban NT-22.
Old 06-14-2009, 09:09 PM   #2
1976 25' Caravanner
Campton , New Hampshire
Not sure exactly what part you are looking for , post a picture , I might have something.
ticki2 is offline   Reply With Quote
Old 06-14-2009, 09:14 PM   #3
That "inlet-outlet" plate is still available.
