Old 02-15-2010, 10:07 PM   #29
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Why do we need a heater?
I'll tell you. Because even here in South Texas during the Vintage rally it got bone cold here for most of the last week and even to week 3 of Feb.
I ordered a new NT30SP which showed up last Thursday, (thanks UPS for delivering it an hour after I left for the rally). Had someone drive it out to me because it was COLD in that trailer. Had a small thermal elec. heater running.
Well since the heater reached me about 4:00 didn't get it installed completely. But at 10:00 that night as temps hit freezing the breaker tripped in the trailer and off went the heater and TV. It overheated and tripped again a few minutes later. So to keep it running I turned it down quite a bit. It got chilly in that trailer that night. So I made it THE priority to get the new furnace running on Friday and did so at about 5:30. Bottom line FURNACE ROCKS! It was very quiet and having it come on and off automatically was music to my ears after nearly freezing Thurs. The heat rises out of the two floor vents and the trailer warms up evenly but it's not like central heating that blows on you in my house.
RichHog is offline   Reply With Quote
Old 02-15-2010, 10:10 PM   #30
webspinner's Avatar
Menlo Park , California
Yup, the NT22A is the heater we had - past tense. It is out of the trailer, internals rotted to heck, and is waiting to donate any vital organs that might be useful elsewhere. We left the case and ducting just in case a future furnace seems in the cards or until we're absolutely sure that isn't the way we want to go. We're keeping our options open at the moment.
Current camping plans won't require much, if any, heat, so we're spending our energy on more urgent projects... like axles.
webspinner is offline   Reply With Quote
Old 02-16-2010, 07:36 PM   #31
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Yes, I found the numbers and it is the dreaded NT22A ...add this little project to the ever growing list of things to do.
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 02-16-2010, 07:43 PM   #32
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
heater
MelloM, I like your heater. Where did you get it? I think thats what Ill do. Thanks
Old 02-16-2010, 08:15 PM   #33
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
You can buy catalytic propane heaters at any well stocked RV Parts Store. Ours is made by Olympian.
Olympian Wave 6 Catalytic Safety Heater - Item - Camping World
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-16-2010, 08:24 PM   #34
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Great, Thanks Mike!
Old 02-19-2010, 04:08 PM   #35
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Yes, I too have the dreaded NT22A.
HAD...pulled it out PO said it works.. Im scared of it and not know anything about a furnace, its headed for the trash heap. On less worry. The good news.. Lots more cabinet space
Old 02-19-2010, 05:53 PM   #36
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I've camped in my B-van in snow and freezing temperatures (down to 18 Fahrenheit one night). If you only ever plan to do summer camping, you can probably get by without a heat source, but I always take some form of heat with me if I'm out in the early spring/late fall/early winter time frame.
The earliest in the season I've camped is mid-March, in the DC area. The latest in the season is this last Christmas, in the Harrisburg, Pennsylvania area. A couple years ago, I stayed in the camper one night in February when the power to the house was out from an ice storm.
My B-van has a furnace, but it has developed a problem wherein it squeals loudly when it first kicks on, which makes it hard to sleep with. So, until I get that fixed, I've been using an electric space heater. It does okay, and it's fine at a campground where there's plenty of power available, but I need the furnace working for April's Cherry Blossom Rally in case it gets cold. Also, I don't like the electric space heater as much because it's in the way on the floor, while the furnace is neatly tucked away and has ductwork to warm both the bathroom and the rest of the camper. The furnace does a much better job making the camper "feel" warm.
Winter camping has its own challenges, but it's as much fun as camping in the summer.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 02-25-2010, 06:43 AM   #37
Arrowstream's Avatar
Columbia , South Carolina
When I had a SOB, I never used the propane furnace; fired it up once or twice to make sure that it worked. I always used an electric, oil filled radiator type heater. I'll probably use a portable a/c instead of a roof top unit also. More versatile, less expensive.
Arrowstream is offline   Reply With Quote
Old 02-25-2010, 07:53 AM   #38
giantTwinkie's Avatar
1988 32' Excella
Bozeman , Montana
hey,heres my two cents.we live in southwest montana and go down by west yellowstone alot.it goes below 32 quite often at night and even occasionally snows even in the summer.i know my wife likes having control of the thermostat.we also have an electric heater in case we are somewhere with electricity.you can always go with, if you have it,you won't need it.
giantTwinkie is offline   Reply With Quote
Old 02-25-2010, 08:11 AM   #39
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
More versatile? What exactly does a window unit do that a RV unit doesn't? As to being less expensive, maybe so; but don't you have to think there is a reason that so many RV owners opt for the more expensive solution?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-26-2010, 08:43 AM   #40
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
One reason for a furnace
So if you are traveling and it's a cold night and you pull off the road at WalMart or roadside park for a few hours your electric heater will be of no use to you. So you turn on the propane, move thermostat to the right and in a few minutes the trailer is warm.
Old 02-26-2010, 01:56 PM   #41
More versatile as in I can move it to my other trailer, use it in the garage, use it anywhere that it's hot and I have electricity. Notice, it's not a window unit.
Old 02-26-2010, 02:13 PM   #42
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
Originally Posted by RichHog View Post
Maybe if someone gives them to you other wise the costs of parts, say in my case a fan motor or blower is over $100. For $375 + $25 you can have a NEW under warranty NT30SP. I'm ordering mine tomorrow. To me I want my Tradewind complete, so it's worth the money to put a new one in and when I'm on the road and it is cold outside and inside, I know that heat is a thermostat away.
Rich, Where can you find one for $400? All the prices I have been finding are $700-800.
I have been using a big buddy hooked up at the point where the furnace propane came in. I really never thought about going camping in the winter. But this year we could not wait til spring so we have go a few times and we enjoy just sitting out there. It would be nice to just have the furnace hooked up.
nick6930 is offline   Reply With Quote
Mr. heater help jpalm1048 Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-05-2010 11:04 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
heater help trea LP Gas, Piping, Tanks & Regulators 7 10-21-2006 02:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
