Old 07-11-2019, 10:59 AM   #15
2017 27' International
Box Elder , South Dakota
You will wish you had two air conditioners the first time you are camped in a very hot climate. Like out west, or in direct sun.
alphamale49 is offline   Reply With Quote
Old 07-11-2019, 11:05 AM   #16
2018 25' International
chino hills , California
23 foot airstream. Two air-conditioners. As others have stated donít think so. We live in Southern California and have many of hot days and only have one air-conditioner for our 25 foot airstream. Never have needed it Even in the triple digits.
redhat200 is offline   Reply With Quote
Old 07-11-2019, 11:17 AM   #17
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
In the great state of TEXAS...hell yes, especially in July and August when the THI gets up to 110 or better. Do it and you won't regret it.
Happy trails.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 07-11-2019, 12:36 PM   #18
2012 19' International
Southeastern MI , Michigan
Originally Posted by Mike G View Post
Our 27' has the 50 amp, two AC option, and I would not do without it. But I can't speak for smaller trailers . . .
I have the 27í and single AC. Have already had 93 degree days in MI where the trailer wouldnít cool below 76 sitting in the sun, which was OK but I need 68 to 70 inside.
For a 23í youíre probably OK but any bigger Iíd get two units.
Countryboy59 is offline   Reply With Quote
Old 07-11-2019, 01:02 PM   #19
Exeter , Rhode Island
No, not with a 23í I have a 32í and definitely need 2 ACís.
Rob30044 is offline   Reply With Quote
Old 07-11-2019, 02:12 PM   #20
California , MD
We ordered a 25 and had a thread on one versus 2 A/Cs. In the end we chose 2 A/Cs.
IMHO, with two A/Cs, the 50 amp power cord is a drawback (heavy and unwieldy)
However, as long as you only run one A/C, you can use a 30 amp cord.
cru-in is offline   Reply With Quote
Old 07-11-2019, 02:47 PM   #21
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Originally Posted by GMFL View Post
Then all you would have to do to run both units in a campground would be to access the 30amp service to power the trailer and then access the 20amp plug with a separate cord to power the second AC unit. Install would have been clean and you would have just needed a second cord to power both. .
Correct me if I am wrong but this may be problematic for a 30A pedestal. Some may be wired in an either/or configuration (using either 30A or 20A but not both) rather than wired for total potential draw (30A + 20A).
Greg
greghoro is offline   Reply With Quote
Old 07-11-2019, 03:03 PM   #22
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Greg
Most pedestals Iíve seen have both 20amp and 30amp breakers so they should be able to carry the own load.
Non the less the pedestal has to be able to carry at least 50 amps to cover that breaker.
If the pedestal is just a 30 amp then you may just not be able to use the second AC. But in most cases I think you would work out fine.
Old 07-11-2019, 09:45 PM   #23
2019 25' International
Washington , Washington, D.C.
Yes, youíre fine
PatLee is offline   Reply With Quote
Old 07-17-2019, 09:13 AM   #24
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you are still shopping and are not (yet) tied to a specific trailer ....
Does the 23' fit your needs? Is a 25' or 27' a better fit in terms of what you want to do? Only you can answer that sort of question. It's more core to all of this than the number of AC units on the trailer.
Assuming that the 23' *does* indeed fit your needs, then one AC is what you get (at least from the factory). Pretty much everybody out there running in a 25' or shorter trailer is doing it with one AC unit. 27' is the traditional "break point" for two AC units from the factory.
My guess is that the sales guy had 23 and 27' confused. Indeed the "make sure it has two A/C units" is very good advice .... on a 27' trailer. People do get confused from time to time .... it's even happened to me
Old 07-17-2019, 09:51 AM   #25
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
We live in the "Great White North" and have a single 13.5k A/C on our 25 + 2 Fantastic Fans ... during the Summer after we clean the snow off the roof when boondocking, we use the open the window technique to keep cool. The other day when the temp hit the mid to high 30's C (90's F for you folks below the 46th parallel) we found the single A/C to work great - no need for 2 A/C's
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 07-17-2019, 10:23 AM   #26
1994 34' Excella
Shalimar , Florida
Originally Posted by Bret Holbert View Post
I'm considering purchasing a used (2015) Flying Cloud 23'. A salesman at a nearby AS dealership (...not the dealership that has this trailer...) said to make sure it has two AC's, as a trailer of that size needs two.
Is this correct? Will one unit sufficiently cool this size trailer?
No you don't need two in my opinion and EXPERIENCE. I have a 1994 Airstream Excella 1000 34' and have a new Atwood 15K+ heatpump. It does very well in northern New Mexico and northwest Florida in temperatures in the mid 90's. It also uses much less amps than the other leading brands/models.
Inholdings is offline   Reply With Quote
Old 07-17-2019, 10:59 AM   #27
2016 30' Flying Cloud
Port Saint Lucie , Florida
My wife is sensitive to heat
So yes in my case as we had just one once and when it failed it was not pleasant for her. We could have limped by on the 2nd if we had one Now I have two. But then we have a 30ft unit
ttsr4us is offline   Reply With Quote
Old 07-17-2019, 12:41 PM   #28
2018 22' Sport
Moss Beach , California
No😎
Tsurfs is offline   Reply With Quote
Supporting two air conditioners JoleneAS Furnaces, Heaters, Fireplaces & Air Conditioning 16 03-04-2019 07:04 PM
1 Micro Air 2 Air Conditioners | Dilemma MarkJUrban Electrical - Systems, Generators, Batteries & Solar 17 10-30-2018 02:43 PM
Atwood Air Command Air Conditioners Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 26 05-02-2018 07:58 AM
2015 30 foot.. One or Two Air Conditioners? grizbear Furnaces, Heaters, Fireplaces & Air Conditioning 23 07-09-2017 10:20 AM
Air Conditioners JAG Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-19-2002 01:25 PM
