Old 08-16-2005, 11:57 PM   #29
1976 31' Sovereign
1961 19' Globetrotter
Phoenix , Arizona
Angry
Tim,
Looks like you used PVC on your rerun of H2O lines. I just ripped out all of the old (split & coroded) copper. Any words of wisdom?
Secondly, has anyone figured out why A/S would install the furnace directly under the kitchen sink? Mine is completed rusted out. I hope to remove next week and try to salvage it!
jsmith351 is offline   Reply With Quote
Old 08-17-2005, 12:41 AM   #30
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I used CPVC. It's made for potable hot and cold water.
The common replacment is to use PEX so you should look into that as an option.
I chose CPVC because it was locally available, cheaper than PEX, and the various joints, 90's, t's etc... are smaller. I also like the idea of glued joints as opposed to crimp or compression.
So far it has worked great. No problems.
Good idea to change out all of your supply lines at once. Sure does take the worry out of having leaks on the road
Originally Posted by jsmith351
Tim,
-Tim
theVAP - Airstream Podcast
Old 08-17-2005, 08:48 AM   #31
desi arnaz's Avatar
a new furnace is cheaper than a new funereal...........
desi arnaz is offline   Reply With Quote
Old 08-17-2005, 09:21 AM   #32
1976 31' Sovereign
Phoenix , Arizona
Wonderful, CPVC availbel at H Depot or Lowes? Or do I need a specialist?
Old 08-17-2005, 10:16 AM   #33
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
I've seen it a Lowe's and Ace Hardware.
-Tim
Old 08-17-2005, 11:10 AM   #34
I believe it to be significant that no manufacturer of RVs use CPVC for fresh water plumbing. Most, perhaps all use PEX.
Mark
'85 Sovereign, 25'
Old 08-17-2005, 02:28 PM   #35
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Yep, this ALWAYS comes up when CPVC is mentioned. That's why the first thing I said was:
-Tim
Old 08-17-2005, 04:11 PM   #36
1976 31' Sovereign
Phoenix , Arizona
Okay I'm game, What are the Pro's and Cons.
PEX-
Pro's- Flexibility, install time, maximize space
Con's-Cost, clamp connections, pinched lines (potential)
CPVC-
Pro's- Cost, sealed connections
Con's- Install time, larger space required
Old 08-17-2005, 04:57 PM   #37
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
PEX-
CPVC-
Missed one...CPVC will crack wide open if frozen, PEX will take a light freeze
For fittings for the PEX you can't beat SharkBite Fittings and they will work on copper to PEX too for those pesky repairs.
Aaron
WBCCI #XXXX AIR #2495
Old 08-17-2005, 05:56 PM   #38
Originally Posted by chuck
assuming that I really *should* buy a new furnace...where's a good place?
I bought a REALLY nice used/refurbished one from Colaw's RV Salvage for $275.00 Works great and I now have the piezo lighter on it. I try to run it once a month to check on it. So far it has worked flawlessly.
Anon is offline   Reply With Quote
Furnace sets off smoke alarm silverback 2002 - 2005 International 37 11-12-2006 08:24 PM
Surburban Furnace Ills - HELP Cat Furnaces, Heaters, Fireplaces & Air Conditioning 22 07-07-2005 07:22 AM
R & R a Suburban Furnace Janets Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 07:19 PM
HELP!! Furnace frustration! Forrest Furnaces, Heaters, Fireplaces & Air Conditioning 18 01-26-2003 07:41 AM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
